BF3 on max settings can use over 2gb of vram @ 1080p
Rubbish.
But Kep is taking that to extremes to argue that Nvidia's solution with less vRam is the better one to AMD's with more vRam simply because Nvidia use less.
Rubbish.
2 x GTX 690s quad sli @1600p maxed out running BF3 use 1.8gb per gpu.
http://www.overclockers.com/forums/showthread.php?t=702655
do stop it - a long thread (and multiple on various forums) - if a card has more than 2GB then the game will use it where possible.
Stop what? You are making it seem like the game needs more than 2GB to be playable at 1080P with max settings or you are just baiting, in which case I will report your post.
I happily played BF3 on full ultra with 2GB 680's at 5760x1080 with no issues, so I urge you to think before you type in future.
lol, why does everything have to turn to AMD vs nVidia. He never even began to talk down those lines. It was a simple point that if you have less memory, you can in theory overclock it better.
This has been proven by a few people with 2GB/4GB 670/680s and it makes sense as to why this is so.
I'm really quite confused as to how the conversation has ended up where it is. Perhaps because Matt and you got super defensive about AMD when really there was no need to.
no I said the game can use more than 2GB at max settings at 1080p , you said it wont and I showed where it can and does.
if you want to report my post then please go ahead - I have posted something factual about 2GB cards.
a gtx 690 is 2 x 2GB cards together in SLI on 1 board , they don't share the vram pool (ie 1 4GB lump)
no im not wrong , but I`ll spell it out for you:
I said it can (not will) use more than 2GB vram - I didn't say what for, but that link (and many others) show it does go above 2GB ram usage , when its available. And as rusty said its going to be for caching - but on a 3GB AMD card it uses more than the 1.8 your getting , since it has more space to work with.
and im not confusing anything - what do you think vram is used for? storing textures , pre and post processing before being sent to the ramdac for display
An old pic of two GTX 690s running BF3 @1600p maxed out
Please check the memory usage.![]()
proves EXACTLY what I said - where the resources are available - BF3 *CAN* use more than 2GB... you are `limited` to 2GB per gpu , of which you have 2 per GTX 690 (it works as a 2GB card).
toms did a review and the 7970 was using pretty much all 3GB , although IIRC BF3 maxes out at about 3.5GB ram usage WHERE AVAILABLE.
what vram usage do you titan guys get out of curiosity on bf3 ultra at 1080p?
