They obviously don't understand the function of oil, nor the effect it can have. Fuel is constantly filling the sump, especially on hard driven cars. My response to this thread is based on discussions with the people who designed the engine and now are responsible for oil approvals.
The fact is liner scuffing can be controlled via the type of detergent in the oil aswell as how it copes with fuel dilution
Shorter drain intervals and hard driving is the reason yours is still ok, will be interesting to see how it looks in a few more miles.
Next oil change send me some old oil and we can have a look how much fuel is in it
Shall do.
From reading up on it, basically seems that the 997.1 cars run too hot, causing bank 2 to potentially score due to getting too hot before the stat open and coolant flows, causing hot spots which can lead to scoring of bank 2. The lower temp stat prevents the hot spots by giving good flow. Yet temperatures within the engine are still hot enough to prevent the dilution you mention. Or so the experts say.
Also the newer 9A1 engine in 997.2 cars has a lower temp stat by default supposedly and they don't suffer scoring, but that's more due to a much better design rather than a thermostat.
The turbo and GT definetely have a lower temp stat by default, those engine also have no scoring issue.
Drop me an email m8 with where to send the oil sample too - [email protected] and I'll send you an oil sample.
