*** The Official Samsung Galaxy S4 ACCESSORIES Thread ***
Guys, where the cheapest place to get a 32Gb/64Gb micro SD card? EBay got some 32Gb Samsung Class 10's for £17.
64Gb are like £50!!!
I'd avoid ebay for SD memory, more fakes than real. Unfortunately due to competitor links (ocuk sell SD cards) I can't link you, but what you want is a SanDisk 64GB Mobile Ultra Micro SD (SDXC) Card - Class 10 UHS-1 + SD Adapter
Thank you :)
£37 delivered a good price? That's from the memory place. The rain forrest has them for £40 delivered.
One more thing... I hate the back on my black S4! Its ugly!
Is there ammeter I can get a back battery cover which looks like the same finish add the front (black mist)?
Why could Sammy Just use the same finish back and front!
Couple of items to add to my recommended list.
Qi Wireless charging: QI receivers/transmitters are dirt cheap now. Get the right one and the RX module is so thin it fits inside the stock case with no bulge at all.
SGP Screen Protector GLAS.t NANO: Tried a thicker glass protector that worked ok, but this Nano is miles ahead. Oleophobic coating is super slippery, better than the actual screen and it's just so clear and thin (0.15mm). Love it, not cheap though :(
[/URL]
Is it worth £28?!
And is a screen protector essential when the S4 uses Gorilla Glass III?
Is it worth £28?!
No of course not, it's very subjective though. Depends on what's important to you? I will say in mitigation, can't imagine it's very cheap to make. The manufacturing failure rate must be high with it being so thin. Being a niche they can charge. MIME also make a really thin one, comes to more with shipping etc.
Pay a third and use one of the cheapo 0.4mm Chinese ones. Does the same job. Though it's a lot lighter, noticeably so and the width down 0.15>0.4 doesn't sound like a lot, surprised me in this application, it is.
It's as near to going command as you can get, it's just not there. I think it's actually better than the actual screen to touch. And yes that can scratch very easily.
Have you tried using NFC tags with the QI receiver installed? i've got on and it seems to totally block the NFC when installed :(
So screen protector is a good idea then?
Personal choice to be honest. I always used to use a screen protector on my phones but I haven't with my S4 and everything has been fine fingers crossed. As long as you take good care of your phone I don't see the problem, but you can never be too safe either I guess.
