Hi all,
New loop is two weeks old and I took the side panel off this morning to make sure everything is looking ok. However, the water in my res has gone a little cloudy. I don't understand it because I have used everything the same as I did with my last loop which lasted 3 years and looked fine. I flushed my rad several times before building the loop. Using XSPC Black tubing, XSPC res top for Laing DDC pump, Heatkiller CPU block (3 Years old), Heatkiller 7970 brand spank, Feser Quad Rad (3 years old) Feser Bi-distilled water, silver kill coil and Feser corrosion blocker. Is cloudy water an indication that bacteria is growing or could it just be coming from my tubing or res?
Hope someone can advise me.
Many thanks,
RoEy
Many thanks,
RoEy
