Bought (not from ocuk) an EK7950 Acetel block. Brand new.
Gave it the once over - all looked good - and started tonight to build my new watercooled system.
First job was to take off the bog standard cooler from the gpu; no problem.Then clean up and place thermal pads and paste ; again no problem.
Next - look to fit block - Again no problem.
Then screw together.... We have a problem
There are nine screw holes and eight work as expected but the ninth will not accept the screw (or any of the eight others) - a careful look it is clear that although the scew hole has been drilled , the top has not been countersunk (I think that is an accurate description - a slight dip in the otherwise flat surface to both semi guide the screw and give it an easier run?).
I managed to move the poor hole (all nine do screw in/out) towards the outer rim so that the centre four (which obviously take the strain)are working.
The one I have left off is the one nowhere near any ram or vrm cooling - bottom left ; looking at the gpu withj the gpu in the centre and ram running round it - dvi,hdmi etc connectors to left.
I will look to get a new fitting from EKG but do members think it safe to set up and run temporarily as is ?
It looks and feels secure - certainly round the cpu .
It's so bl....y frustrating when everything grinds to a halt all because of one screw fitting
