Owning a 458 is an exciting but dangerous affair.
The sleek Italian lines and 4.5litre V8 562BHP engine are enough to make anybody go weak at the knees.
The intelligent suspension and clever double clutch gearbox makes the 458 one of the most desirable drivers exotics on the market today.
But there is also the ever present danger that you will end up in a ditch, on fire.
Here at Overclockers UK we value the safety of our customers beyond anything else.
That is why we are suggesting that you purchase the new Thrustmaster GTE Wheel Ferrari 458 Challenge Edition Add-On for T500 RS.
With this fantastic product, you are able to convert your Thrustmaster T500 RS Simulator Racing Wheel into a replica 458 GTE.
The T500 RS is one of the most realistic and high quality simulation level peripherals on the market today and is used widely by simulation enthusiasts as the wheel of choice.
The 458 Add-On is a direct fitment to this steering wheel and offers you an affordable alternative to Ferrari ownership without the risk of injury or death
Thrustmaster GTE Wheel Ferrari 458 Challenge Edition Add-On for T500 RS @ £99.95 inc VAT
The Thrustmaster 458 CHALLENGE replica wheel is officially licensed by Ferrari and installs easily on your T500RS or Ferrari F1 Wheel Integral T500 wheel base.
- 11” / 28 cm in diameter
- Reinforced rubber texture on the wheel’s entire circumference
- Brushed metal central spokes (2 mm thick) with metallic paint
- Weighs more than 2.6 lbs / 1.2 kg, for ultra-realistic inertia and Force Feedback
- 6 easy-access, clearly identified action buttons
- 3-position Manettino® dial with push function in the center
- 1 multidirectional D-pad
- 2 large sequential paddle shifters, attached to the wheel
- 5” / 13 cm tall
- Crafted of 2 mm-thick brushed metal + metallic paint
- Very high-end tact switch (lifecycle of more than 10 million activations)
Only £99.95 inc VAT.
ORDER NOW
Thrustmaster T500 RS Simulator Racing Wheel for PS3 & PC (Licensed for Gran Turismo 5) @ £339.95 inc VAT
Only £339.95 inc VAT.
ORDER NOW
Overclockers UK - Don't Die in a Fire.
- 5” / 13 cm tall
ORDER NOW
ORDER NOW
