Drain line help
26 Mar 2009
I'm ready to plan my watercooling loop now and I really want a drain to line to help for future draining/cleaning. I'm thinking in adding a T junction at the lowest point of the loop with a drainage tube coming off the T junction. However I'm confused in what parts I would need to get this done, how would I cap the end of the drain line :confused:
I'm using 1/2" ID - 3/4" OD tubing with monsoon compression fittings. I would be very grateful if someone could tell me what parts I would need to add the T line with drainage to my loop :D
look at my buildlog thread (in sig) I have a drain at the bottom with a T-Section like you mention and a second one on the side. Also have the parts listed for it too.
You need:
T Piece - http://www.overclockers.co.uk/showproduct.php?prodid=WC-144-BP&groupid=962&catid=2589&subcat=2592
Fill Port - http://www.overclockers.co.uk/showproduct.php?prodid=WC-077-OE&groupid=962&catid=1529&subcat=2588
2 Compression fitting or barbs
Stop Cap - http://www.overclockers.co.uk/showproduct.php?prodid=WC-181-EK&groupid=962&catid=1529&subcat=2588
male/male connector - http://www.overclockers.co.uk/showproduct.php?prodid=WC-113-XS&groupid=962&catid=1529&subcat=2588
You will also need a hole cutter to drill through the case
I'm looking at having a piece of tubing coming from the T piece itself. I'm using the 900D and due to health problems it wouldn't be safe for me to move/lift the case to allow drainage from below.
Good idea though :)
Good idea though :)
depending how your rad is located you may well have to be moving it around to get all the fluid out!
Problem with leaving a tube attached to the T-piece is that you end up with a lovely stagnant liquid trap in the tubing.
You need one QDC with a 1/4" screw thread to go into the T-Piece and the opposite (male or female) QDC that has a compression fitting for the tubing. Then you just plug the QDC with the tubing into the QDC on the T-piece.
