I'm putting a new virtual server together to replace my 3 old Q6600 machines. I'm opting for a Xeon based Supermicro m/b, which has 2 CPU sockets.
My main PC runs the H60 model, so I want to use a pair of these, or H80s with the new build.
But as they will both need a 120mm fan hole/port/slot/vent (whatever you call them), I'm not sure which case will be able to supply that.
I'm looking at tower cases primarily as I have 6-8 HDDs to drop in there too. My desktop case is the Thermaltake Overseer, whcih has a 120mm fan at the back, but the rest are 200mm. I guess a case with 2 x 120mm fans at the back or one at the back and one on top would be spot on.
Can anyone suggest a case or cases I should be looking at?
I'll get back to clicking all the cases and checking the specs out for now
**Edit: Typical isn't it. Almost all cases I've looked before I posted were 200mm fans on the top. Then I find a raft of ones with 120mm. I think we might have a winner tho. The Xigmatec Elysium seems to tick every box (http://www.overclockers.co.uk/showproduct.php?prodid=CA-015-XG&groupid=2362&catid=1572).
Anyone got any good/bad experiences with this case?
