Its only a matter of time before the limit is breached, but even so id still expect 2gb to be plenty for single screen @1080p for a while. With the consoles having lots of usable memory though it will happen, just a question of when.
If I was AMD I would STFU until they release the 8000 series.....
Also unless you game at 1440p 2GB is enough. Hell 1GB is enough for me.![]()
+1
this advert is talking about a single card setup and there is no way that a single card could drive settings that would require 3GB of VRAM, so really what they are advocating is crossfire setups for 2560x1440... in which in their own advert they then admit that there is a glaring issue with their own drivers for crossfire
This isn't true, and I wish people would stop spreading it.
Memory consumption and GPU power aren't really linked.
Memory intensive doesn't mean GPU intensive, and most stuff that fills up memory doesn't really make that much of a difference to FPS except for lots of AA and things like ambient occlusion.
As for this advert, it's clear what they're angling at, but the way they've portrayed it is misleading.
2GB is an issue but only as a result of it being on a 256bit bus, as the bus is the actual issue it's just that 2GB is like a secondary issue to that as you wouldn't typically have 2GB on anything but a 256bit bus currently.
Very high resolution textures would fill up VRAM without much of an impact to FPS.
That's one example, and generally speaking, the type of settings that pull down GPU performance are computationally "expensive" ones, where the memory footprint isn't increased so much, but the GPU is being taxed.
So one can actually be raised without the other, it's that simple. In addition to that, there's no reason why having more available GPU power will increase VRAM usage either.
Welcome back Spoffle.![]()
Modded Skyrim then![]()
Upping ingame settings to "max"
The fan favourite (modding Skyrim) is an addon and not needed to play the game, you make a conscious decisions to add the textures/mods and shouldn't be used in an argument towards VRAM usage imho....as it's a gamers choice.
The other is turning ingame settings up to 11, you either turn the game into a slideshow through hitting a VRAM wall or because you don't have enough GPU grunt to churn those settings, your example is the latter, although not memory heavy it still increases memory load albeit tiny in comparison to the likes of AA whilst having a similar effect on the framerate.
^^ This.
From a non biased perspective Nvidia have a tight lineup now, from bottom to top a card for every segment. Although AMD have cards with similar performance for less money they have no answer to the GTX 780 or Titan, doesn't have to beat either but same ballpark / less cost would make things more competitive. New cards would generate more interest.. Hopefully AMD announce something soon..
The 7990 is more than an answer to either, regardless of it being a dual gpu solution.
A dual GPU isn't an answer to a monster single GPU..
The GTX 880 is going to be a monster I tells ya, GPGPU Compute / Monster Gaming performance the whole enchilada.
