Today we present some awesome graphics deals! Save up to £139... deals to be had. Be quick!
kfa2 geforce gtx 770 ex oc 2048mb gddr5 pci-express graphics card (77xph6dv6kxz) @ £299.99 inc vat
the next generation geforce gtx 770 is a high-performance graphics card designed from the ground up to deliver super-fast, smooth and quiet gaming. it features the most advanced technology innovations, engineering and features to deliver spectacular performance in today's most demanding games.
features:-
- innovative new geforce architecture, designed to deliver faster, more power-efficient performance
- nvidia gpu boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- the power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with nvidia fxaa
- the power of 3-way nvidia sli® technology
- ultra-smooth gaming experience with exciting new nvidia technology advancements
- nvidia adaptive vertical sync adjusts vsync to current frame rates for maximum playability
- nvidia 3d vision® surround multi-monitor gaming on a single gpu (three gaming monitors plus one accessory display) - for the first time ever
- supercharged nvidia physx® and nvidia 3d vision® performance
- new 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
specification:-
- core clock: 1110mhz (gk104)
- core boost clock: 1176mhz
- memory: 2048mb gddr5
- memory clock: 7010mhz (effective)
- memory interface: 256-bit
- processing cores: 1536
- shader clock: 2220mhz
- bus type: pci-express gen 3.0 (backwards compatible)
- display connectors: 2x dual-link dvi-i, 1x hdmi 1.4a & 1x displayport
- sli ready (upto 3-way sli supported)
- hdcp capable
- directx 11 support
- opengl 4.0 support
- physx enabled
- cuda enabled
- 3d vision enabled
- nvidia surround enabled
- lower power consumption (maximum consumption 230 watts at stock speed)
- 1x 8-pin & 1x 6-pin pci-e connectors required
- warranty: 2 years
- product review: http://www.guru3d.com/articles_pages/kfa2_geforce_gtx_770_ex_oc_review,23.html
Only £299.99 inc VAT.
ORDER NOW
Sapphire HD 7990 6144MB GDDR5 PCI-Express Graphics Card @ £799.99 inc VAT
With more than twice the processing power of previous generation AMD discrete graphics cards, ATI Radeon HD 7900 Series graphics cards deliver a cinematic gaming experience and unprecedented performance.
Features:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- HD 7990 is a dual GPU card
- Core Clock Speed: 950MHz
- Core Boost Speed: 1000MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 64 CU / 4096 ALU
- Texture Units: 256
- ROPS / Z-Stencil: 64 / 256
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 2x384 bit / 6000MHz
- Load / Idle Board Power: <500W / <3W
- Power Connectors: 2x 8-pin required
- Display Outputs: DL-DVI-I, 4x Mini-Displayport
- 2yr Warranty
Only £799.99 inc VAT.
ORDER NOW
features:-
specification:-
- hdcp capable
- physx enabled
- cuda enabled
- 3d vision enabled
- warranty: 2 years
ORDER NOW
Features:-
- 2yr Warranty
ORDER NOW
