Geforce GTX 760 1080P Performance Review (LinusTechTips)
2 Jan 2012
UK.
Very variable reviews around when you compare the 760 and the 7950.
The 7950 crushes it in the slides above, however other reviews show it the other way round.
http://www.anandtech.com/show/7103/nvidia-geforce-gtx-760-review/18
Linus overclock the gpu's using light overclocks. Paid review sites run their 7950's at 880/1250. Once you clock the 7950 its a match for the 770, never mind a 760.
Another thing you will often notice with review sites is disabling settings or graphical options in game to make performance look better on the product being reviewed. The good thing with Linus is he doesn't appear to be biased to either side in anyway.
Agreed, hard to find an unbiased review these days. A lot of the big review sites getting a kickback in some form or other, Linus is decent, as is that guy that likes the heavy metal music lol.
Just from the spec you can see the 7950 is going to beat the 760, I'm actually surprised the 760 beats the 660ti considering how fewer cuda cores. the extra rop's and memory bus / overclock seem to make up the difference. The HD 7950 def remains the bang for buck card to get. Wish AMD would release some competition for the 780 and Titan though.. Time for some new cards / competition..
Any reason this warrants it's own thread seeing as a 760 benchmark thread already exists.
I mean beyond the fact it goes against the general grain of existing reviews and therefore makes one set of tedious fanboys happy.
I'm not sure their is anyone here at OCUK that would consider themselves a fanboy of midrange cards? So your implication is a bit odd..
Surely it's beneficial to have a whole view of a cards performance. Are you saying that Linus's reviews don't count?
I don't have bias either way, but base my purchases on value, thought the thread would benefit those who are thinking of buying one of these..
Oh come on now.. you know as well as I do that there are a core bunch of dullards here who will argue red vs. green no matter what.
Not at all, I just wonder why a review that seems to go against the grain warrants it own thread? Surely it would be better in the main review thread, where it can be better compared with other reviews and reviewer methodology.
Fair enough. I'm just sick and tired with a core group of clowns (not you) who have pretty much ruined this forum with their constant bickering, in EVERY SINGLE GOD DAMN THREAD. Every time, the same, over and over again.
.. and breathe
So if I'm reading the overclock table correctly (which I'm probably not:)) they have clocked the 7950 core by 200mhz and the memory by 225mhz, and the 760 core by 100mhz and the memory by 100mhz.
It helps to explain why these results are vastly different to all of the other reviews I have read.
Image removed.
I think you might find 760 a bit overclock limited due to lack of voltage control and the fact its not using the new 1750 mhz memory IC modules as seen on the 770. Not to mention the fact its a 670 but with a core clock increase so unless its hard a large voltage bump i can't see the overclock limits increasing much.
This makes the review pretty pointless.
Linus does a typically average overclock only on the cards so its something every user can obtain relatively easily. For example his 7970 is only at 1100/1575 which is nothing at all.
If you want to compare cards, compare them at stock and max overclock.
Picking a random overclock, mild or not, introduces too much bias. The OC on the 7950 is twice that of the 760.
I work in publishing and, although I don't work specifically in the PC tech sector, I'd be astonished if it's true. In video games (that's my area) the common belief is that this sort of thing happens all the time and the reality is that's just not true.
Problem with "max" is it can go either way depending on the card you've got, not saying mild is a better alternative but it's more of a real-world result.
Comparing at stock is important though because no OC is guaranteed :)
Good luck finding a 760 that will overclock anywhere near the level a Tahiti card will with full voltage control on the core and the memory. You've got two chances. Fat chance and no chance.
What are you saying here? You're gay? I'm gay? Gay is in some way an insult?
Actually, is this a come on? Something from the private collection perhaps. A bit of internet argy bargy is your thing? Well I'll say I'm flattered, but at least cough up for dinner first chap.
Sorry the image just cracked me up and seeing your pot kettle black rant it seemed approapriate. Just joking of course. :p
I understand what your saying, but I cannot help but notice that linus is using an extra 20% power on the 7950 but only 6% extra on the 760 when the 760 can allow up to 15% extra power.
Hover over and click the 760 core overclock box/graph and it says "110 worked but power limit tweaked on and off". So i guess there was either a driver issue or the card wouldn't overclock further maybe. :confused:
