- 16 Nov 2011
I am wanting to get a new graphics card, I have 2304 x 1440 and 2560 x 1440 monitors (only use one for gaming). I am not sure which card would be the best, on one hand I would like a really good card and on the other I know that it won't be that long until Maxwell and Sea Islands. I only get a few months a year to play games and I do not want to waste it.
I am looking at these options.
GTX 760 (£190) then a new card this time next year
GTX 760 sli (£380)
GTX 770 4GB (£340)
GTX 770 2GB sli (£600)
The GTX 760 in sli does seem to in some games beat the Titan, however in others it does not even beat the 770. My thinking is that there is some limiting factor in the GTX 760 that is causing loss of performance for very intensive games. For example if you look at Crysis 3 at lower resolutions the Titan beats two 760s, then as the resolution and graphics settings goes up the two 760s are the clear winner against the Titan. However when you reach very high levels of intensity(lower then 20FPS) the two 760s drops off dramatically not even beating the GTX 770. I am thinking that this might be caused by the memory bandwidth as the GTX 680 has the same memory bandwidth as the GTX 760, and the GTX 680 suffers from the same affect. Maybe a memory OC would help this?
I am wanting to be able to play "next gen" games such as Watch Dogs and Unreal 4 games at resolution at decent FPS (30), obviously if there is a massive drop off at about 20 FPS it does not really matter since I would turn the resolution down.
The other option would be the get a single GTX 760, as even a single GTX 760 can play almost every game at 2304 x 1440 and considering that the monitor is a CRT slightly lower FPS is ok and I can turn the resolution down to 1920 x 1200.
And then there is of course the option of GTX 770 in sli which would play everything, but would it be worth it as I could just save money then get a new card this time next year.
Current PC specs:
3930k, not yet OCed
P9X79 Pro
16 GB DDR3 2133
AX 850
HD 4870 1GB
GTX 760 sli (£380)
GTX 770 4GB (£340)
Current PC specs:
3930k, not yet OCed
P9X79 Pro
16 GB DDR3 2133
AX 850
HD 4870 1GB
