- 4 Jan 2013
- kent
Fair enough would you not fancy watercooling your current system and rebuilding it? Although would be a shame as would void the system warranty with Ocuk. Maybe just get a cheap system spec as above and then get some used watercooling parts or the kit that you mentioned and then maybe you could just use that on your system one day. One good thing with watercooling parts is that they last and you only need to update the blocks.
i was thinking it, but i'd rather not. plus like you said, it would void the warranty and when i first got this pc it was nothing but problems lol so the warranty is certainly needed.
