using windows 8. Ive changed the pagefile now need to disable hibernationhttp://www.computing.net/howtos/show/solid-state-drive-ssd-tweaks-for-windows-7/552.html
0 affects aslong as you have some pagefile,2gb is fine
Either remove some RAM, buy a bigger SSD or disable hibernation and investigate reducing the pagefile size if it's appropriate to your usage.
It's a valid suggestion. An unlikely one I admit, but valid nonetheless.
Move pagefile to secondary harddrive and delete the old pagefile. Done
Should the pagefile be placed on SSDs?
Yes. Most pagefile operations are small random reads or larger sequential writes, both of which are types of operations that SSDs handle well.
In looking at telemetry data from thousands of traces and focusing on pagefile reads and writes, we find that
Pagefile.sys reads outnumber pagefile.sys writes by about 40 to 1,
Pagefile.sys read sizes are typically quite small, with 67% less than or equal to 4 KB, and 88% less than 16 KB.
Pagefile.sys writes are relatively large, with 62% greater than or equal to 128 KB and 45% being exactly 1 MB in size.
In fact, given typical pagefile reference patterns and the favorable performance characteristics SSDs have on those patterns, there are few files better than the pagefile to place on an SSD.
-25
seriously. it's not good advice. you want your pagefile on the fastest disk. it certainly doesn't do SSDs any harm if that's what you think.
http://blogs.msdn.com/b/e7/archive/2009/05/05/support-and-q-a-for-solid-state-drives-and.aspx
reduce the size by all means but keep it on the SSD.
