Gaming upgrade £750 budget!
5 Aug 2009
Hey guys, I'm looking for some suggestions on upgrading my PC to basically be able to run the Witcher 3 game on close as to max settings. I run all my games at 1920x1080. If possible I'm like a Midi tower (like the corsair obsidian 350D), but if that will put me massivley overbudget, then I can go without.
I currently have:
i5 2500k @ 3.3ghz
4gb Ram
AMD 6950
Seagate 1TB Sata HD
Many thanks in advance
Thanks!
Whats the difference between the 650D case and the 350D case (besides prices)
The 350D has fewer expansion slots, not as many hdd bays and no fan controller. Also does`nt have a window. The Cpu height is 160 max and it only fits mATX or mITX mobos.
So if you decided on the 350, you would need to change the mobo and cooler.
