- 24 Dec 2007
Hi, quick question here regarding my next case. In my build plan for my next pc I'm currently thinking about running the 540 air. I'm wondering if any of you can tell me if it improves performance enough to warrant the price increase over the other 3 options in the title thread? If not, which of the other 3 would be best for the spec below?
I realise there isn't a huge amount of benchmarks or anything regarding the 540, so I'm just after guestimates, essentially. I'm quite worried the 540 won't be out before the end of August, as I need the build by September.
Bear in mind, I'm going to be overclocking my 4670k to 4.5-4.8Ghz, and my 7950 quite a bit too, so air cooling is going to be important. I'd also like to know if these would all fit an H100 or if I would have to drop that to something else?
YOUR BASKET
1 x MSI HD 7950 Twin Frozr III Boost Edition 3072MB GDDR5 PCI-Express Graphics Card **NEW REVISION** £239.99
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - OEM with FREE Grid 2 PC Game £179.99
1 x Asus Z87-PLUS Intel Z87 (Socket 1150) DDR3 ATX Motherboard £143.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black £116.99
1 x Samsung 128GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD128BW) £115.99
1 x XFX Pro Series 650W XXX Edition Modular '80 Plus Bronze' Power Supply £74.99
1 x TeamGroup Vulcan GOLD 8GB (2x4GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLYD38G2133HC11ADC01) £71.99
1 x Corsair Hydro H100 Extreme Performance Liquid CPU Cooler *Manufacturer Refurbished Unit - 90 Day Warranty £39.95
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £11.99
Total : £1,009.96 (includes shipping : £11.75).
Thanks in advance!
YOUR BASKET
Thanks in advance!
