Caporegime
- 18 Sep 2009
- Dormanstown.
You're probably better off building it mate, 2K's getting steep for just a 4770K, I mean you could quite easily have a 3930K at 2K.
Well that's just confused me even more!
I've just found out we're getting an even bigger redundancy package than previously thought (mining industry) and now I'm tempted to do something silly like get this monster... http://www.overclockers.co.uk/showproduct.php?prodid=FS-368-OE&groupid=43&catid=2474 that should easily last me 3 years with that insane GPU...
To be honest, I really don't know. In 2-3 years time there might be tech out that will be better than SLI/Crossfiring a GPU right? As long as a rig lasts me ~3 years I would be happy, and even more so if I could upgrade some components rather than buying a fresh system.
Hi Kaapstad, what do you mean that a 3930 SB-E is more upgrade able? Do you mean it is easier to overclock it later on than a Haswell?
I assume previous comments about a 7990 being overkill would also apply to your dual-GTX780 suggestion if I am just playing on a single monitor setup?
Cheers,
Mark
 Yeah that build doesn't make sense to me either, I think we've established that dual-GPU is overkill for my needs.
