5040x1050 gaming in 120hz I wont give up anytime soon.
my 7970 runs it just fine.
Even the cheapest 780 is grossly overpriced though.
my 690 tops out at 40 degrees and makes 0 noise, literally. also doesnt stutter!![]()
If you want a single card would go for the best value GTX 780 or HD 7970 you can find. Some good prices can be found now even on the 780's. If your happy to run 2 cards HD 7950 is best bang for buck. Personally I'm not going dual cards again, sensitive to stutter, and to much noise / heat. Rather lower settings and have a smooth experience..
I don't have any shutter issues. My 2 770 Lightnings in SLI are quiet and purring like kittens. System fans are the loudest things and even they are quiet.
