***AMD/ATI RADEON 8970M 4GB HASWELL LAPTOPS NOW AVAILABLE!!***
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
The laptops you've being waiting for, featuring immense power from the HD 8970M 4GB Graphics and Haswell processors. These new laptops look absolutely amazing, so much more attractive than the last chassis, better power consumption and immense gaming performance.
OcUK Hardcore Gamer P177SM 17.3" LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, ATI Radeon HD 8970M 4GB GDDR5 Graphics Card - Windows - Black @ £1229.90 inc VAT
For hardcore gamers who want the best in mobile gaming, look no further than the OcUK Hardcore Gamer P177SM. There is no more powerful or better constructed option, with the latest 4th generation (Haswell) Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Hardcore Gamer P177SM with an Intel I7 Extreme processor too. Though our own in house testing shows the best bang for buck performance comes from the Intel Core I7 4800MQ & 4700MQ processors, so we highly recommend these when choosing a processor option.
This chassis uses the absolute very latest in technology such as SATA3, USB3.0, Bluetooth, WiFi but the most impressive of all is the fact this system features an ATI Radeon HD 8970M with 4GB of GDDR5 dedicated memory for absolutely blistering performance. With so much video memory and such horsepower you can even output to a 30" monitor and still have great gaming performance or run a multi-monitor setup.
With an LED backlit 17.3" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the ATI HD 8970M's onboard graphics. The OcUK Hardcore Gamer P177SM features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
For memory we only use the highest performance and most reliable for laptops, which is Corsair Vengeance which is set to run at 1600MHz with T1 memory timings resulting in absolute instant response. 8GB is the default choice which is more than adequate for all task and gaming, we only recommend 16GB kit if your also doing a lot of photography work or heavy multi-tasking. Corsair Vengeance 1600MHz will extract the very best performance from the OcUK Hardcore Gamer P177SM causing zero bottlenecks in the system.
For hard drive options, we recommend the primary drive as an SSD drive, this means from point of pressing power on your should be at the Windows 8 Desktop in approx 10 seconds and with an SSD applications and games load more or less instantly. Of course if you preferre capacity you can choose a large capacity HDD or a Hybrid drive too. Our recommendation is to select an SSD for the primary drive along with a HDD as the secondary drive for storage.
When you buy a Overclockers UK system/laptop the only software you’ll find is your choice of operating system. We guarantee that there will be no third party apps, useless bloatware or unnecessary trial software, to keep your machine running at peak performance from the start. We also only install the latest drivers which are proven to provide maximum performance when gaming.
Specification:-
- Operating System: Choose from the drop down options!
- Display: 17.3" SuperBright LED True HD Display (1920x1080 Resolution)
- Graphics: AMD / ATI Radeon HD 8970M 4096MB GDDR5
- Storage: Choose from the drop down options!
- Optical: Choose from the drop down options!
- Illustrator touchpad (glows when used)
- Sound Blaster HD Audio
- Mic Noise Suppression
- Dolby Home Theatre®
- 4W THX Stereo Speakers (2W x 4)
- 2 megapixel Webcam
- Processor: Intel® Core™ i7 4th Generation Haswell Processor - Choose exact model from drop down options!
- Memory: 4GB DDR3 System Memory at 1600MHz (4GB x 1) OR choose 8/16GB DDR3 Options
- Main Chipset: Intel HM87
- Communication: 10 / 100 / 1000 Gigabit Ethernet LAN,Wireless LAN, Widi Support
- WiFi Options: Choose from drop down menu
- 1x HDMI Port
- 1x DisplayPort
- 1x Mini-DisplayPort
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x Mini IEEE 1394a port
- 1x eSATA Port (USB 3.0 Combo)
- 1x DC IN
- 1x RJ-45 Jack
- Kensington Lock: YES
- Full Range AC adapter, AC in 100~240V, 50~60Hz, DC output 19.5V, 11.8A, 230W
- Removable 8 cells Smart Lithium-Ion battery pack, 76.96WH
- Battery life: 300 minutes (with UMA mode, 76.96WH Battery)
- Dimensions: 414 (W)x286 (D)x 25.3~46.1 (H)mm
- 4.1Kg,including ODD and 76.96WH Battery
- 9in1 Card Reader
- 2yr Warranty (1yr Parts, 2yr Labour)
Service Package
- Full 24 Month collect and return warranty (12 month on parts)
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this Notebook for You?
Immense performance, powerful graphics and sleek hardware all combine to create the "OcUK Hardcore Gamer P177SM, perfect for the gaming enthusiast.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow between 48 and 96 hours for your system to be built and configured. This may take longer during busier periods. You can choose from the drop down options to jump the queue by selecting one of our Fast Track options. If your choosing the 24hr next day service, to get the laptop delivered next working day you need to order pre 10:30am to give us enough time to build, test and get your laptop shipped out, otherwise you will get it the following day.
FROM £1229.90 inc VAT.
ORDER NOW
OcUK Hardcore Gamer P157SM 15.6" LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, ATI Radeon HD 8970M 4GB GDDR5 Graphics Card - Windows - Black @ £1179.90 inc VAT
For hardcore gamers who want the best in mobile gaming, look no further than the OcUK Hardcore Gamer P157SM. There is no more powerful or better constructed option, with the latest 4th generation (Haswell) Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Hardcore Gamer P157SM with an Intel I7 Extreme processor too. Though our own in house testing shows the best bang for buck performance comes from the Intel Core I7 4800MQ & 4700MQ processors, so we highly recommend these when choosing a processor option.
With an LED backlit 17.3" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the ATI HD 8970M's onboard graphics. The OcUK Hardcore Gamer P157SM features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
For memory we only use the highest performance and most reliable for laptops, which is Corsair Vengeance which is set to run at 1600MHz with T1 memory timings resulting in absolute instant response. 8GB is the default choice which is more than adequate for all task and gaming, we only recommend 16GB kit if your also doing a lot of photography work or heavy multi-tasking. Corsair Vengeance 1600MHz will extract the very best performance from the OcUK Hardcore Gamer P157SM causing zero bottlenecks in the system.
Specification:-
- Display: 15.6" SuperBright LED True HD Display (1920x1080 Resolution)
- 1x HDMI Port
- 1x DisplayPort
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x DC IN
- 1x RJ-45 Jack
- 9in1 Card Reader
Service Package
FROM £1179.90 inc VAT.
ORDER NOW
Of course if you can't wait until end of this month, we have in stock right now the GTX 765M 2GB Haswell laptops, check them out:-
OcUK Gamer W370ST 17.3" LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, NVIDIA GTX 765M 2GB GDDR5 Graphics Card - Windows - Cosmic Grey @ £979.90 inc VAT
For gamers the OcUK Gamer W370ST is the perfect choice. There is no more powerful or better constructed option, with the latest 4th generation (Haswell) Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Gamer W370ST with an Intel I7 Extreme processor too. Though our own in house testing shows the best bang for buck performance comes from the Intel Core I7 4702MQ & 4700MQ processors, so we highly recommend these when choosing a processor option.
This chassis uses the absolute very latest in technology such as SATA3, USB3.0, Bluetooth, WiFi but the most impressive of all is the fact this system feature an NVIDIA GTX 765M with 2GB of GDDR5 dedicated memory for absolutely blistering performance. With NVIDIA Optimus technology means you can game on move whilst still maintaining respectable battery life.
With a LED backlit 17.3" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the NVIDIA GTX 765M onboard graphics. The OcUK Gamer W370ST features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
For memory we only use the highest performance and most reliable for laptops, which is Corsair Vengeance which is set to run at 1600MHz with T1 memory timings resulting in absolute instant response. 8GB is the default choice which is more than adequate for all task and gaming, we only recommend 16GB kit if your also doing a lot of photography work or heavy multi-tasking. Corsair Vengeance 1600MHz will extract the very best performance from the OcUK Gamer W370ST causing zero bottlenecks in the system.
Specification:-
- Graphics: NVIDIA GTX 765M 2048MB GDDR5 with NVIDIA Optimus technology
- 1x HDMI Port
- 2x USB3.0 Ports
- 1x USB2.0 Port
- 1x E-SATA
- 1x VGA
- 1x DC IN
- 1x RJ-45 Jack
- 8 Cell Smart Lithium-ION Battery
- 9in1 Card Reader
Service Package
Immense performance, powerful graphics and sleek hardware all combine to create the "OcUK Gamer W370ST", perfect for the gaming enthusiast.
FROM £979.90 inc VAT.
ORDER NOW
OcUK Gamer W350STQ 15.6" LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, NVIDIA GTX 765M 2GB GDDR5 Graphics Card - Windows - Cosmic Grey @ £929.90 inc VAT
For gamers the OcUK Gamer W350STQ is the perfect choice. There is no more powerful or better constructed option, with the latest 4th generation (Haswell) Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Gamer W350STQ with an Intel I7 Extreme processor too. Though our own in house testing shows the best bang for buck performance comes from the Intel Core I7 4702MQ & 4700MQ processors, so we highly recommend these when choosing a processor option.
With a LED backlit 15.6" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the NVIDIA GTX 765M onboard graphics. The OcUK Gamer W350STQ features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
Specification:-
- 1x HDMI Port
- 2x USB3.0 Ports
- 1x USB2.0 Port
- 1x E-SATA
- 1x VGA
- 1x DC IN
- 1x RJ-45 Jack
- 9in1 Card Reader
Service Package
Immense performance, powerful graphics and sleek hardware all combine to create the "OcUK Gamer W350STQ", perfect for the gaming enthusiast.
FROM £929.90 inc VAT.
ORDER NOW
Any questions just ask! :)
I've been doing a lot of looking around recently for a 4800MQ, 8GB Ram, 8970M 15.6" and they've come to just over £1.3K. OCUK equivalent is £1,279.91 PLUS you can use quidco to bring this down to £1,241.51 (None of the other sites had this without them being £100+ more in the first place).
Really impressive pricing.
Glad to hear it, the new 8970M chassis really is amazing, I love the new touchpad and graphic equalizers, all adds to the wow factor. :D
I was looking at the W370ST. I was also looking at the ****** LG175. Similarly configured the **** comes out nearly 200 quid cheaper. There are some aspects that are difficult to compare from the descriptions - e.g. quality of the display; general build quality; quality of the chassis; quality of the speakers (although I'd normally use headphones anyway). And it's not possible to choose identical drive configurations. Any opinions on the relative merits of the two?
As an aside - anyone have any experience putting linux on either of these?
At the risk of necroing, I was left with a slightly itchy feeling when I first realized that the 15" laptops have slightly too identical descriptions and pictures to the 17" ones... I was wondering if there was any chance of clarifying whether there were any meaningful differences (hopefully there are in e.g. dimensions ;)), and possibly getting some pictures up for both to show any differences in layout or design?
you should compare it to 780 more then 765 or 770 (in both cases quicker) and about 5% slower then 780 - 300 notes cheaper :P
