Hey guys
I'm looking for a case for a build, I've got anywhere between £50-100 to spend on the case, but ideally £80 or less as I'd like to put the £20 into fans/fan controllers etc. We were originally looking at the Bitfenix Shinobi, but as far as I know the H100 cooler doesn't fit in it - nor in the Corsair 200R or 300R, which were backup options.
This is to fit a sort-of-top-of-mid-range PC, so cooling isn't totally essential and should be somewhat covered by the H100. Specs are looking to be a HD7870 and a 4670K with a moderate overclock, there's no target on the OC though, I'll just match the clock to the temps.
Things we're looking for
1) Fits an H100 (240mm radiator) plus fans in the top or back of the case - only has to be in push or pull, not P/P
2) A couple of filtered intakes ideally on the front
3) A clean look, not too many vents (I find they let more dust in, I'd rather have the airflow controlled and through filters.
4) A windowed side panel (or windowed side panels available)
5) Black interior
6) £50-100 (ideally <£80)
7) Holes (preferably with rubber protection) in the motherboard tray for cable management
Any form of built in fan control, or sufficiently good included fans would mean that I can spend closer to the £100 end on the case, so that I'd save money on fans/fan controllers. If necessary I can stretch the budget and cut back somewhere else - I'd rather get him a good case with slightly compromised GPU, for example, as the case can last a few builds.
I'd rather avoid Antec or CoolerMaster - too many vents.
Any suggestions?
Thanks
5) Black interior
Any suggestions?
Thanks
