- 29 Jun 2013
Looking for the best graphics card for my custom built pc with an i7 and 16gb ram. Anybody know what is best for my PC for constant gaming? Really want the most graphics power for my budget of £100
I would try and stretch your budget to a £130 2gb 650ti boost as it will be able to play decent graphics where as any of the cheaper cards will be struggling.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-199-MS&groupid=701&catid=1914
Agreed with Doom.Your priorities don't seem right here mate..
a lot of the gaming performance of the PC comes from the GPU, so to spend £270 on a CPU and £100+ on RAM and only £100 on a GPU is absurd.
All you really need for a gaming system is an i5 (4670k), 8Gb of Fast RAM (its the speed that makes the difference not the amount) and a good £220-£250 GPU, (7950,760 ECT..)..
what do you think?
The Inno3D GeForce GTX 650TI iChill Herculez is a boost model and cheaper than the one you have linked too. hence why I linked to it earlier.
Agreed with Doom.
Was gonna say the exact same thing.
Let's hope so. Far too many members ask for advises, and toss them right out the window and gone with their gut-feelings in the end thesedaysGlad to see im talking sense.
I just hope he takes notice and realises that that is the case.
Let's hope so. Far too many members ask for advises, and toss them right out the window and gone with their gut-feelings in the end thesedays![]()
Unless im missing something why spend all that money on an i7 and only get a £100 GPU? i7 would be overkill for most people let alone for gaming! my i5 2500k never gets pushed that hard and that can be had for £140ish now??
Id seriously recommend getting an i5 and putting another £100-150 into a GPU.
what do you think?
Agreed with Doom.
