Spec:
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Nehalem) (Socket LGA1366) - Retail
Asus P6T SE Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel (TR3X6G1600C9)
Sapphire HD 5770 1GB Graphics Card
Corsair HX 650W ATX Modular SLI Compliant Power Supply
Antec P183 Case
+ 2x 1tb hd.
Basically had the above for almost 4 years now at stock and it's obviously beginning to struggle in games to point where I'm considering buying a new system. On that I'm kind of in two minds, buy now or wait for new AMD/Nvidia graphics stuff later in the year/next year.
The other option I guess would be to finally try overclocking. I've never really needed to before so not even looked into it, let alone done it. I mainly play Planetside 2 which is extremely cpu limited and would be wanting to play Rome 2 and BF4 I guess.
So with that in mind, would it be worth overclocking the cpu in this, and assuming I don't trash the thing buy a newer graphics card like a 7870 or 660Ti? and use that for a year or so. Or am I going to be better off just buying a new system?
There are obviously loads of guides on how to overclock this cpu around the web, are there any that you would particularly recommend? I would just be looking for a decent performance boost whilst being stable, not going right to the limit or anything.
Other than that, assuming it's worth doing and relatively easy for a novice, any recommendations on what I should use in terms of cooler, thermal paste and what if any graphics card to go with this + anything else I'd need. All of that assuming the PSU will allow for any of this.
Appreciate any advice/thoughts on this. Thanks.
Antec P183 Case
+ 2x 1tb hd.
