Moth in my bran flakes!
6 Oct 2007
North West
Freshly opened box, took a few spoon fulls then noticed a moth splattered to the side of the bowl drowned in milk, should I report this to kellogg's or just let it slip?
Are you sure the moth didn't just happen to fly into your cereal? If it definitely was inside the box, then I'd contact them.
There's a moth in mi Branflakes, what am I gonna do?
I'm gonna fix that moth, that's what I'm gonna do
When you open your mouth you don't talk, you shout
And you give everybody the blame
When they catch you up they will shut you up
And you got no one to blame
When you out on the street, you practice lies and deceit
And you scandalize my name
When I catch you up, I'm gonna pull you up
I'm gonna check-out inside your brain
When you deh pon the scene, you make everyone scream
Because they know you're so unjust
When they catch you up, they will kick you up
Because you're someone they can't trust
________________
I would not watch this film.
I inspected it with my spoon and there was no leg or wing movement so I doubt it just decided to dive in to my cereal and take a milk bath. The bowl was only left unattended for a few seconds when I went for the milk, obviously I did not observe a moth in the bowl before I poured the milk.
I think I will call them, put me right off my bran this has, back to special K.
Are you suggesting the combined weight of the cereal and milk was enough to 'splat' the moth to the side of the bowl. Or more likely, it was on the bowl to start with :confused:
A moth in white bowl would be very noticeable would it not? I have perfect vision, there was no moth in the bowl prior to the flakes being served.
