3 Jul 2013 at 12:28 #21 WuMyster WuMyster Associate Joined 28 Feb 2012 Posts 1,851 Location London, UK Unless youll use the macros, theres practically no difference. Also, you wanted Red or Blue LEDs didnt you?
3 Jul 2013 at 12:30 #22 seanr28 seanr28 Associate OP Joined 26 Jun 2013 Posts 233 Ok I have narrowed it down, do I go with the Corsair K70 or the CM STORM QUICK FIRE TK ?
3 Jul 2013 at 12:55 #23 seanr28 seanr28 Associate OP Joined 26 Jun 2013 Posts 233 Oh well, I have bitten the bullet and gone for the K70 Thanks for all your input and help
3 Jul 2013 at 12:58 #24 nemtizz nemtizz Soldato Joined 16 May 2006 Posts 14,699 Solid choice, sir. You won't regret it!
3 Jul 2013 at 13:15 #25 Robbo Robbo Man of Honour Joined 2 Jan 2009 Posts 63,422 The K70 is excellent, only reason I didn't recommend it is because of the red switches (you said you wanted black/brown)!
3 Jul 2013 at 14:35 #26 seanr28 seanr28 Associate OP Joined 26 Jun 2013 Posts 233 Robbo said: The K70 is excellent, only reason I didn't recommend it is because of the red switches (you said you wanted black/brown)! Click to expand... I did, until I read about the red ones
3 Jul 2013 at 16:09 #27 Jony27 Jony27 Soldato Joined 15 Aug 2010 Posts 8,931 Location N. Ireland Just ordered myself a CM Quickfire TK with brown switches Should be here tomorrow, first mechanical keyboard! Whoop
