£1200-£1300 Build for a friend.
27 Mar 2009
Hello could you guys please check my spec i built for a friend, he is planning to use it for streaming and heavy gaming. He is looking to spend around £1200 but would consider going higher to £1300, any advice or improvements are more thank welcome thank you.
Total £1,186.86
Nope no sli plans, which of the cpu coolers would you recommend? Also is ram compatible with the Gigabyte G1.Sniper M5 Intel Z87
just remember the coolers mickyflinn has linked are pre-order and arent expected untill 3-4 weeks.. just incase ur wanting to get it all set up when you order it.
that H100 is worth it for £40, so i'd recommend waiting that little bit longer, or ordering it seperately and make do with the stock cooler until it comes, then replace it.
Would definitely cut down the motherboard to something like D3H, what features you need from a board that cost £170??
We are building it, and hes dead set on the NZXT case. Which liquid cooler can you guys recommend the one in the build already is alright but is there any better ones that are in stock?
My buddy Idleman has done a great build. Personally I would also take the K2 over the H80.
If you can't wait on the refurb'd H100 then the Antec 1220 is the next best and cheapest option.....
YOUR BASKET
2 x MSI HD 7950 Twin Frozr III Boost Edition 3072MB GDDR5 PCI-Express Graphics Card **NEW REVISION** £239.99 (£479.98)
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail with FREE Grid 2 PC Game £194.99
1 x Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £131.99
1 x Antec Kúhler H2O 1220 Series 4 High Performance Liquid CPU Cooler ( LGA 1150 / 1155 / LGA1156 / LGA1366 / 2011 / AM2 / AM2+ / AM2+ / AM3+) £97.58
1 x Toshiba SSD HG5D Series THNSNH 7mm 128GB Solid State Hard Drive - (THNSNH128GCST) £91.99
1 x XFX Pro Series 750W XXX Edition Modular '80 Plus Bronze' Power Supply £85.99
1 x NZXT Phantom 410 Enthusiast Midi Tower Case - White £84.95
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (PV38G240C0K) £64.00
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £49.99
1 x LG GH24NS95 24x DVD±RW SATA ReWriter (Black) - OEM £19.99
Total : £1,330.79 (includes shipping : £24.45).
Pity you don't get free P&P :( The 7950 comes with free games, as this is an Xfire setup he'll double up on the games so could flog off the extra codes to recoup some cash.
YOUR BASKET
Awesome Spec Hono, Shame bout the P&P, would bring it so close to budget..
Though selling the game will bring you back into budget anyway, even if you keep one set. :)
I want that build. :)
