***MOBILE GAMING LIKE A BOSS - HASWELL GTX 780M 4GB LAPTOP!!***
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
OK being burning the midnight oil for this, well nearly, but am sure its a laptop specification you've all being waiting for. Haswell with GTX 780M 4GB, this is the absolute king of the single GPU laptops, for gaming performance. Of course if it was my money I'd personally buy one of our 8970M 4GB based laptops as they offer very close to the performance for a few hundred quid less.
BUT if you want the absolute best gaming performance laptop, this is it, so check it out and get your pre-orders placed as these will be a very hot seller for sure:-
OcUK Hardcore Gamer P170SM 17.3" LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, NVIDIA GeForce GTX 780M 4GB GDDR5 Graphics Card - Windows - Black @ £1,499.90 inc VAT
For hardcore gamers who want the best in mobile gaming, look no further than the OcUK Hardcore Gamer P170SM. There is no more powerful or better constructed option, with the latest 4th generation (Haswell) Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Hardcore Gamer P170SM with an Intel I7 Extreme processor too. Though our own in house testing shows the best bang for buck performance comes from the Intel Core I7 4800MQ & 4700MQ processors, so we highly recommend these when choosing a processor option.
This chassis uses the absolute very latest in technology such as SATA3, USB3.0, Bluetooth, WiFi but the most impressive of all is the fact this system features an NVIDIA GeForce GTX 780M with 4GB of GDDR5 dedicated memory for absolutely blistering performance. With so much video memory and such horsepower you can even output to a 30" monitor and still have great gaming performance or run a multi-monitor setup.
With an LED backlit 17.3" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the NVIDIA GeForce GTX 780M onboard graphics. The OcUK Hardcore Gamer P170SM features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
For memory we only use the highest performance and most reliable for laptops, which is Corsair Vengeance which is set to run at 1600MHz with T1 memory timings resulting in absolute instant response. 8GB is the default choice which is more than adequate for all task and gaming, we only recommend 16GB kit if your also doing a lot of photography work or heavy multi-tasking. Corsair Vengeance 1600MHz will extract the very best performance from the OcUK Hardcore Gamer P177SM causing zero bottlenecks in the system.
For hard drive options, we recommend the primary drive as an SSD drive, this means from point of pressing power on your should be at the Windows 8 Desktop in approx 10 seconds and with an SSD applications and games load more or less instantly. Of course if you preferre capacity you can choose a large capacity HDD or a Hybrid drive too. Our recommendation is to select an SSD for the primary drive along with a HDD as the secondary drive for storage.
When you buy a Overclockers UK system/laptop the only software you’ll find is your choice of operating system. We guarantee that there will be no third party apps, useless bloatware or unnecessary trial software, to keep your machine running at peak performance from the start. We also only install the latest drivers which are proven to provide maximum performance when gaming.
Specification:-
- Operating System: Choose from the drop down options!
- Display: 17.3" SuperBright LED True HD Display (1920x1080 Resolution)
- Graphics: NVIDIA GeForce GTX 780M 4096MB GDDR5
- Storage: Choose from the drop down options!
- Optical: Choose from the drop down options!
- Sound Blaster HD Audio
- Mic Noise Suppression
- Dolby Home Theatre®
- 4W THX Stereo Speakers (2W x 4)
- 2 megapixel Webcam
- Processor: Intel® Core™ i7 4th Generation Haswell Processor - Choose exact model from drop down options!
- Memory: 4GB DDR3 System Memory at 1600MHz (4GB x 1) OR choose 8/16GB DDR3 Options
- Main Chipset: Intel HM87
- Communication: 10 / 100 / 1000 Gigabit Ethernet LAN,Wireless LAN, Widi Support
- WiFi Options: Choose from drop down menu
- 1x HDMI Port
- 1x DisplayPort
- 1x Mini-DisplayPort
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x Mini IEEE 1394a port
- 1x eSATA Port (USB 3.0 Combo)
- 1x DC IN
- 1x RJ-45 Jack
- Kensington Lock: YES
- Full Range AC adapter, AC in 100~240V, 50~60Hz, DC output 19.5V, 11.8A, 230W
- Removable 8 cells Smart Lithium-Ion battery pack, 76.96WH
- Battery life: 300 minutes (with UMA mode, 76.96WH Battery)
- Dimensions: 414 (W)x286 (D)x 25.3~46.1 (H)mm
- 4.1Kg,including ODD and 76.96WH Battery
- 9in1 Card Reader
- 2yr Warranty (1yr Parts, 2yr Labour)
Service Package
- Full 24 Month collect and return warranty (12 month on parts)
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this Notebook for You?
Immense performance, powerful graphics and sleek hardware all combine to create the "OcUK Hardcore Gamer P170SM, perfect for the gaming enthusiast.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow between 48 and 96 hours for your system to be built and configured. This may take longer during busier periods. You can choose from the drop down options to jump the queue by selecting one of our Fast Track options. If your choosing the 24hr next day service, to get the laptop delivered next working day you need to order pre 10:30am to give us enough time to build, test and get your laptop shipped out, otherwise you will get it the following day.
Only £1,499.90 inc VAT.
ORDER NOW
There it is, mobile game on the move like a boss! :D :D :D
Hi there
We now also have a GTX 770M 3GB version available too:-
OcUK Hardcore Gamer P170SM 17.3" LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, NVIDIA GeForce GTX 770M 3GB GDDR5 Graphics Card - Windows - Black @ £1190.90 inc VAT
This chassis uses the absolute very latest in technology such as SATA3, USB3.0, Bluetooth, WiFi but the most impressive of all is the fact this system features an NVIDIA GeForce GTX 770M with 3GB of GDDR5 dedicated memory for absolutely blistering performance. With so much video memory and such horsepower you can even output to a 30" monitor and still have great gaming performance or run a multi-monitor setup.
With an LED backlit 17.3" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the NVIDIA GeForce GTX 770M onboard graphics. The OcUK Hardcore Gamer P170SM features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
For memory we only use the highest performance and most reliable for laptops, which is Corsair Vengeance which is set to run at 1600MHz with T1 memory timings resulting in absolute instant response. 8GB is the default choice which is more than adequate for all task and gaming, we only recommend 16GB kit if your also doing a lot of photography work or heavy multi-tasking. Corsair Vengeance 1600MHz will extract the very best performance from the OcUK Hardcore Gamer P170SM causing zero bottlenecks in the system.
Specification:-
- Graphics: NVIDIA GeForce GTX 770M 3072MB GDDR5
- 1x HDMI Port
- 1x DisplayPort
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x DC IN
- 1x RJ-45 Jack
- 9in1 Card Reader
Service Package
Only ££1199.90 inc VAT.
ORDER NOW
OcUK making it easy to Mobile Game like a BOSS! :D :D :D :D
What is the cooling like on 780 model chassis ? I got to say that is quite a nice price for the Hardcore gamer one, I've been seriously considering buying a new laptop and was looking at the new Alienware's. But that hardcore gamer one is like almost 1k cheaper :eek:
Because Alienware have like 60-70% profit margin. :D
Were a lot more reasonable, same performance or better for far less money. :)
The Alienware will have a sturdier chassis and the hardware to bypass Optimus. Also, a better warranty, but Dell's support is suspect in the UK. We don't know about the AW'S cooling yet, but it should be at least on par with the Clevo's.
I don't know if Alienware is worth the "price hike" in the UK, but you should be able to haggle.
I can confirm these machines are extremely capable.
The gap between desktop and laptop in terms of gaming performance is getting smaller and smaller every quarter.
Heres my 3Dmark11 results;
http://www.3dmark.com/3dm11/6826421
If one GTX 780M is not enough, then have two:- ;)
OcUK Ultimate Gamer P370SM3 17.3" 120Hz 3D LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, NVIDIA GeForce GTX 780M 4GB GDDR5 SLi Graphics Cards - Windows - Black **PRE-ORDER** @ £2,377.91 inc VAT
For those who want the ultimate gaming laptop then look no further than the OcUK Ultimate Gamer P370SM3. If you need serious graphics gaming horsepower, this laptop features a pair of NVIDIA GTX 780M 4GB cards configured in SLI. With the latest 4th generation (Haswell) Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Ultimate Gamer P370SM3 with an Intel I7 Extreme processor too. Though our own in house testing shows the best bang for buck performance comes from the Intel Core I7 4800MQ & 4700MQ processors, so we highly recommend these when choosing a processor option.
This chassis uses the absolute very latest in technology such as SATA3, USB3.0, Bluetooth, WiFi but the most impressive of all is the fact this system features two NVIDIA GeForce GTX 780M with 4GB of GDDR5 in SLI configuration. dedicated memory for absolutely blistering performance. With so much video memory and such horsepower you can even output to a 30" monitor and still have great gaming performance or run a multi-monitor setup.
With an LED backlit 17.3" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the NVIDIA GeForce GTX 780M onboard graphics cards in SLI. The OcUK Ultimate Gamer P370SM3 features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
For memory we only use the highest performance and most reliable for laptops, which is Corsair Vengeance which is set to run at 1600MHz with T1 memory timings resulting in absolute instant response. 8GB is the default choice which is more than adequate for all task and gaming, we only recommend 16GB kit if your also doing a lot of photography work or heavy multi-tasking. Corsair Vengeance 1600MHz will extract the very best performance from the OcUK Ultimate Gamer P370SM3 causing zero bottlenecks in the system.
Specification:-
- Display: 17.3" SuperBright LED True HD 120Hz 3D Display (1920x1080 Resolution)
- Graphics: 2x NVIDIA GeForce GTX 780M 4096MB GDDR5 in SLI
- Built in 3D IR emitter plus one NV 3D Vision 2 shutter glasses
- 1x HDMI Port
- 1x DisplayPort
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x DC IN
- 1x RJ-45 Jack
- Dimensions: 419 (W)x293 (D)x 39.3.3~49.7 (H)mm
- 3.9Kg,including ODD and 76.96WH Battery
- 9in1 Card Reader
Service Package
Immense performance, powerful graphics and sleek hardware all combine to create the "OcUK Ultimate Gamer P370SM3, perfect for the gaming enthusiast.
Only £2,377.91 inc VAT.
ORDER NOW
Wow, OCUK, you really have stepped up you're game!
You're the cheapest re-seller of the P170SM in UK (from what I have researched)
Long gone are the days of me recommending to go else where to save £100~ OCUK all the way!
That along with Alienware messing up and going back to their trusted super overpricing, don't see why you wouldn't purchase you're new laptop from you lot.
Now all you need to do is get yourself an eSports team!
Gibbo that is just totally mean ! now I want one of the P370SM3 :(
That is a pretty darn exceptional price for the 2x 780's. *Looks at money stashed away for new laptop...*
Thank you! :)
Have you seen the new 13.3" Piranha were doing, its 1920x1080P with a GTX 765M 2GB all crammed into a 13.3" chassis. :D
As someone who is a very long time lurker and daily forum visitor, all I can say is WOW! OcUK, you guys are really pulling out all the stops! These machines you're getting are pretty amazing, especially at those prices <3
If the ETA is correct for the OcUK Ultimate Gamer P370SM3 - 09/08/13.
Early next month I shall be purchasing one ! (after pay day :p)
Single 780m Benchmarks continued;
Hitman Absolution
Tomb Raider
Hi there
I've just ran same benchmarks on an OcUK P157SM with 8970M 4GB Graphics using exactly same settings as yourself at 1920x1080 as I assumed that is the resolution you ran at:-
Lastly a picture of the laptop. :)
Sorry about the photo's just took them with my phone on my very messy desk. :D
Too summarise:-
GTX 780M 4GB is 11% faster in Tomb Raider at 1920x1080p over HD 8970M 4GB
GTX 780M 4GB is 20% faster in Hitman Absolution at 1920x1080p over HD 8970M 4GB
In short the GTX 780M is hugely powerful, but for the money the HD 8970M sometimes comes within 10% in games of 780M and cost considerably less. :)
Why only as default have a 60gb HDD, only 4gb ram, and no OS? To pull people in with a lower initial cost?
I'm not having a dig, genuine question!
Yes.
The default spec is traditionally the lowest cost, then people either buy that or customise it to their needs. :)
