phantom nxzt case fans
28 Feb 2013
Leeds
hello peeps. Just got myself a phantom nxzt at a steal.
But... It didnt come with the standerd fans it should.. so. does anyone know if they can be purchased separatly or do I need to buy after market ones, which im sure oc will do :)
Thanks
Thanks
I had this same question, you can't purchase the matte white painted LED fans. I contacted NZXT who said they don't sell them (which really p'd me off - so you have to buy a whole new set).
You can however buy clear plastic colored LED fans, or matte (non-LED) fans. They have them on the OCUK store.
This one looks very similar to the one found in a Phantom 410 and perhaps any similar model.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-001-NX&groupid=701&catid=2331
Those are the same fans as the standard case fans, but without the LEDs.
Go aftermarket. I've got a Phantom 410 and I've binned off the original fans. Compared to the fans I have now they were awfully loud.
