I'm planning to upgrade from my i3-2120 build to Haswell, hopefully by the end of August, and would like some opinions/advice please.
My current build is:
I have been gradually upgrading it since I built it with a £300 budget (although I overspent by £130) last year.
After upgrading to Haswell I won't be upgrading anything else for a while (at least a year if I can avoid it). My current plans for the Haswell upgrade are:
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - OEM £187.99
1 x Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £131.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black £116.99
1 x Arctic Cooling MX-2 Thermal Compound (4g) £6.98
Total : £455.95 (includes shipping : £10.00).
The rest of the parts will be moved from my current build
I have a H100i ready to use with the new CPU, staying in the box for now as I don't think it is worth putting on my i3-2120.
Is that board a good choice? Is there a better board you would choose around the same price? (If so, why is it better?)
Also, is there anything else I should consider upgrading before I leave it alone? (Hopefully not)
I'm not likely to ever need SLI/Crossfire, I do intend to try overclock the CPU to around 4.5 (if I can).
YOUR BASKET
