I've currently got an Antec 900 build which i'm considering upgrading key components rather than buying or building a whole new system. Taking the opportunity to optimizing cooling as well. This is primarily a gaming upgrade looking ahead but a good allrounder.
The parts I'm changing:
Motherboard
CPU
Graphics Card
RAM
The parts I'm considering:
Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-437-GI
CPU
http://www.overclockers.co.uk/showproduct.php?prodid=CP-479-IN&groupid=701&catid=6&subcat=567
or
http://www.overclockers.co.uk/showproduct.php?prodid=CP-475-IN&groupid=701&catid=6&subcat=567
if it is worth the extra £45?
Graphics card:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-116-GI&groupid=701&catid=1914&subcat=1830
RAM:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-132-CR
What would you suggest for a CPU cooler? I've currently got the Arctic Freezer Pro 7
This has been suggested to me
http://www.overclockers.co.uk/showproduct.php?prodid=HS-035-CM
I've also been looking at this one
http://www.overclockers.co.uk/showproduct.php?prodid=HS-000-EN
Or I'm also considering taking advantage of the offer Overclockers have on the Corsair hydro range or would any of the conventional air fans be better?
http://www.overclockers.co.uk/showproduct.php?prodid=HS-022-CS
Using the corsair H80 i would have to remove the exit fan at the top back of the case.
I have the Antec 900 case with two intake fans at the front, the big exit fan on the top and another exit fan at the top back. Do you think any other fans would help or do you think what i have is sufficient in keeping it cool? For example i could have another on the side panel either intake or outtake, or more behind the hard drive bays at the front behind the two intake fans.
I'm open to suggestions about other components if you feel they are just better or worth a little extra cost.
Thanks
Motherboard
CPU
Graphics Card
RAM
Motherboard
CPU
or
Graphics card:
RAM:
Thanks
