- 20 Aug 2007
- Solihull
http://www.overclockers.co.uk/showproduct.php?prodid=CA-118-CS
Opinions from any owners? Is it reliable?
This one is well woth the extra £7..
http://www.overclockers.co.uk/showproduct.php?prodid=CA-013-XF&groupid=701&catid=123&subcat=1497
What rig are you building?
You'll only really need 750W if going SLI/Xfire, if youre not a 550W/600W PSU will be fine.![]()
you can get a platinum rated psu for that money
http://www.overclockers.co.uk/showproduct.php?prodid=CA-191-AN&groupid=701&catid=123&subcat=2463
i would go for a 750 bronze over a 550 plat. bit more breathing room.
The XFX is a far superior unit to the CX series. Built by Seasonic too.
really. really though,
http://www.guru3d.com/articles_pages/evga_geforce_gtx_690_review,7.html
and the 690 is a very efficient card.
I imagine OP is even more confused now!
thanks for all the input though guys, I'm now even more confused though for sure.it is a single card. in so far as its a card, which is single.
regardless, a 750w psu is not an extravagant expense. its what i would consider a sweet spot to be honest.
