need An upgrade asap
19 Mar 2010
Hey all
I have 500 pound budget to use either for a new PC or upgrade.
I have an windows 7 nvidia with 9200 graphics card with 3GB memory.
Its 32 bit and its AMD 2 x 3 425 processor with 2.70 GZ.
Can you suggest a way to upgrade this or is it worth buying another one .
Can you let me know please asap.
Thanks
cooldog6923
Id say you certanly need a new CPU, Motherboard, RAM, GPU and that sort of stuff..
What is your Case, PSU, HDD and OD? are the HDD and OD SATA?
What do you use the PC for?
Case - PACKARD BELL - IMEDIA S3210
Motherboard. Make and model.
Cpu.
Ram(memory). - 3GB
Gpu. Make and model.
HDD/SDD. - 250 GB INTERNAL PLUS 1 TB EXTERNAL
Optical drive.
Cooler, if you have one(not including stock cooler).- NO COOLER
OS(64/32bit) - MICROSOFT WINDOWS 7 - 32BIT
Also, what are the main used for this system? And will you be building it?
MAIN USE IS GAMING AND I WILL HAVE TO GET SOMEONE ELSE TO DO .
i WILL ADD MORE INFO LATER BUT BASICALLY IS AN packard bELL - imedia S3210 SO ALL OTHER INFO SHOULD BE EASY TO FIND OUT .
Have you tried toying around with the custom PC configurator on the main shop page?
It can at least give you a rough idea of what to expect for your budget.
Also if you need someone else to build it for you then id probably suggest you get a custom made machine/bundle from OCuK. They know their stuff and they deliver super fast.
Im still using a custom build I bought 2 years ago from them!
MOTHERBOARD IS Foxconn DAO61/O87L Socket AM2 Motherboard
Suitable for Acer Aspire X3200, X1300 & X1301
Onboard VGA, PCI Express graphics card slot, 2 x DDR2 memory slots,
Ethernet (LAN) port for broadband connection and networking,
2 x Serial ATA (SATA) ports,
External Serial ATA (SATA) port,
HDMI port & onboard multi channel audio
cpu IS amd ATHLON(TM) 2 X3 425 PROCESSOR , 2700 MhZ, 3 CORE, 3 LOGICAL PROCESSOR.
I was going to try this one - is this the best I can get for 500 pounds .
AMD FX-4 4100 3.6Ghz CPU, AMD 760G Motherboard, 1600MHz DDR3 Memory, DirectX 11 Graphics Card, 500GB HDD + Upgrade Options, DVDRW, Choice of Windows Operating System, 430W Corsair PSU
4gb memory
windows 7 - home premum 64 bit
seagate barracuda 1TB
NVIDIA geforce GTX 650 1024 MB GDDR5
AMD x 4 RAID
