- 4 Nov 2007
So I've just replaced my 480 with a less power-hungry Sapphire 7950 OC Boost.
First impressions are great, then I decided to simply install Sapphire Trixx and bump the core up to 1000mhz. All I did was move the core from 925mhz to 1000mhz and press apply.
There's no problem with the clock at all, just that gpuz is now showing it permanently locked to 1.163v, and not undervolting to 0.800v when at idle clocks anymore.
The clocks are still scaling as expected but the volts just sit reporting at 1.163v. This happened immediately upon changing the max frequency to 1000mhz.
I've tried uninstalling Trixx to no avail, and I've done a complete fresh driver install with driver fusion also, and the volts still no longer scale.....stuck at 1.163.
Does anyone have any pointers on getting the scaling volts back?
-edit-
Following a screen freeze when trying to load up Trixx......idle voltage is now back down around 0.800. I think I'll be leaving Trixx alone for a while.
-edit-
