- 27 Sep 2012
- Petone, NZ
RESOLVED (kind of): see post 23 for spoilers
I bought a *B-GRADE* Sapphire HD7950 OC from OCUK late last year and have been having system crashes during gaming ever since. I am at my wit's end so have resorted to the unthinkable: asking for help.
Usually after 10-30 mins of gaming the picture will freeze (but no artefacts), the sound will either stop or skip, and after a few more seconds the PC will reboot (Windows 124 error). It will only ever happen once per gaming session. Once the PC reboots I can play for hours will no more issues.
How long it takes to crash seems to be a function of which game I play... Arma2 can crash it in 5-10 mins if I sit in the menu. In GTR2 it'll typically last 40 mins or more. So it looks like a function of load - either graphics or full system load or both.
Facts:
I get these crashes whether it is at the factory OC or reference 800GHz, (CPU at stock or OCed, same result)
The temperatures seem very much under control -- last crash happened at GPU 54C, VRMs 50 & 52C. I've never seen the GPU or VRM temps higher than 70C.
What I've tried so far:
At first I thought this kind of crash sounded like RAM, so I've replaced that and changed slots.
My CPU was running pretty hot so I've replaced the cooler and now getting 40s under load. Voltage is boosted slightly bc its sensitive to that.
I've replaced my crappy 550W PSU with a nice XFX 650W one... actually I thought this had fixed it I didn't have any crashes for a week but they came back -- Is this some kind of clue?
I've pushed the voltage slightly to 1.13 to see if it helped stability, it didn't.
I've lowered the VRAM to 1200GHz but it didn't help.
I've tried reseating the card, tried the other PCIe slot
I've removed drivers, cleaned, manually deleted files & reg keys, installed new driver.
I have not yet reinstalled Windows, although at some point I may give in and do this (but I'll hate myself for it). EDIT: Have now tried it, no help
I feel there is heaps of other stuff I've tried that I can't remember.
Here is the bit where you shake your head... I'll avoid eye contact for a bit...
When I got the card it was 5mm too long for my case, and the cooler 5mm too thick to clear my HDD bay, so I opted (probably unwisely) to let it flex slightly and push against the HDD bay while I tried it out. It was like this for a few weeks and then I cut the stupid plastic 'horns' off the cooler so that it now fits properly. If there was any chance of RMAing it before, there is none now. I know, tut tut tut
I got the occasional crash since the start, but not every single gaming session like now.
Maybe I have screwed it putting it under that small twisting force. Either way, is this a dodgy graphics card or could it still be something else?
Has anyone else seen this same pattern before?
Game for 30 mins --> full system crash --> reboot --> game forever
Thank you very much for reading this far and for any help you can offer.
Facts:
