- 20 Jul 2009
- The bleak North East arm pit of Britain
You cant beat the Edifier R1600T for quality and performance at £77.99inc! At £49.99inc you would be forgiven to think they were priced too cheap! BBQ season is here so break out the BBQ with some burgers, beers and some awesome tunes!
Edifier R1600T Studio Plus 2.0 Monitors ** BBQ SPECIAL!! ** @ £49.99 inc VAT
** PRE ORDER PRICE **
The Edifier R1600T Plus is a professional low-noise amplifier with all wood enclosure. The high performance crossover provides superior coverage while magnetic shielding prevents interference. The 5-inch bass driver is designed using a composite cone structure for a truly balanced acoustic. Built-in, side-mounted controls mean volume, treble and bass are at your fingertips. Dual RCA inputs allow connection of two additional devices for maximum flexibility in your set-up.
- Professional low-noise amplifier coupled with high performance crossover.
- 4.5inch bass driver - designed using a composite cone structure for a balanced acoustic.
- Silk diaphragm 18 mm tweeter with aluminum phase plug.
- Side mounted rotary volume, bass and treble controls.
- All wood enclosure.
- Power Output: RMS 2 × 16W
- Signal to noise ratio: 85 dBA
- Distortion: 0.1%
- Bass unit: 5 inch (120mm), magnetically shielded, 6ohm
- Tweeter unit: 18mm silk dome tweeter, magnetically shielded, 4 ohm
- Input impedance: 10K ohm
- Input sensitivity: 550 mV ± 50 mV.
- What's in the box:
- 1 x Active speaker
- 1 x Passive speaker
- 1 x 3.5mm to RCA connector cable
- Audio connecting cable
- User manual
- Dimensions: 152(W) x 252(H) x 228(D) (mm)
Was £77.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOWhttp://overclockers.co.uk/showproduct.php?prodid=SP-003-ER
- Distortion: 0.1%
- User manual
Was £77.99 Inc. VAT
