Its BBQ weather so break out some tunes!!
20 Jul 2009
The bleak North East arm pit of Britain
You cant beat the Edifier R1600T for quality and performance at £77.99inc! At £49.99inc you would be forgiven to think they were priced too cheap! BBQ season is here so break out the BBQ with some burgers, beers and some awesome tunes!
Edifier R1600T Studio Plus 2.0 Monitors ** BBQ SPECIAL!! ** @ £49.99 inc VAT
** PRE ORDER PRICE **
The Edifier R1600T Plus is a professional low-noise amplifier with all wood enclosure. The high performance crossover provides superior coverage while magnetic shielding prevents interference. The 5-inch bass driver is designed using a composite cone structure for a truly balanced acoustic. Built-in, side-mounted controls mean volume, treble and bass are at your fingertips. Dual RCA inputs allow connection of two additional devices for maximum flexibility in your set-up.
- Professional low-noise amplifier coupled with high performance crossover.
- 4.5inch bass driver - designed using a composite cone structure for a balanced acoustic.
- Silk diaphragm 18 mm tweeter with aluminum phase plug.
- Side mounted rotary volume, bass and treble controls.
- All wood enclosure.
- Power Output: RMS 2 × 16W
- Signal to noise ratio: 85 dBA
- Distortion: 0.1%
- Bass unit: 5 inch (120mm), magnetically shielded, 6ohm
- Tweeter unit: 18mm silk dome tweeter, magnetically shielded, 4 ohm
- Input impedance: 10K ohm
- Input sensitivity: 550 mV ± 50 mV.
- What's in the box:
- 1 x Active speaker
- 1 x Passive speaker
- 1 x 3.5mm to RCA connector cable
- Audio connecting cable
- User manual
- Dimensions: 152(W) x 252(H) x 228(D) (mm)
Was £77.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOWhttp://overclockers.co.uk/showproduct.php?prodid=SP-003-ER
i dragged out my old Denon DM31 for the bbq last weekend, speakers that size are ideal, youre hardly aiming for epic-boom or symphony orchestra reproduction
I've got a couple of the Zeppelins, the big one and the small one and both work epic for BBQ's. I did move some floor standers into my garden a few years back and blew the buggery out of one of them as it didn't take all day at close to full power running. So if anyone wants 1 Monitor Audio Studio floor stander let me know :(
that woman should be using a lambs wool wash mitt.
surely someone should have informed her that a sponge is not ideal for washing the vehicle.
Focal? Rather not, I'm Sonos for my in and outdoor audio needs ;)
Oh you ;)
Couldnt agree more! Quality ambient music for the money. Good :cool:
You should replace with a set of edifier.. small, easy to move about and look rather classy too! :)
i remember in university halls when we had a BBQ outside I used to just put my 115/120w guitar amp in my window and have my laptop hooked up.... did the trick rather nicely :D only needed it on about 3-4 volume level to fill the area with sound hehe
I would have to hear them first unfortunately, where can I go for a demo? Who else stocks them? ;)
*snip*
You can hear them in our store or.....
Buy them, try them, send them back if they are no good to you but if you check the reviews online you will see they really are very very good for the money and customers all seem to be happy :)
Can you confirm if these are the FK452 of the speaker world?
lol!
Premium budget summer tyre... Id say these are more like the AS2s, lacking behind the PSS and no where near the AD08...
Atleast im not trying to pitch these as the "TOYO PROXY T1R"..
Ill get my coat
Genuinely didn't know this was a thing you could do, fair play.
Edit:Why are you using Gibbos real name as your name Nath!?
Gibbos real name is "Andrew Gibson", Nath is still nathwraith with his Mugen CRZ, I have the mugenised FN2 and I am Andrew Moore..
