Today's deal, fresh out the oven
OcUK Hardcore Gamer P177SM 17.3" LED Full HD Intel Haswell Processor, 1600MHz DDR3, SSD + HDD, ATI Radeon HD 8970M 4GB GDDR5 Graphics Card - Windows Laptop - Black @ £720.00 inc VAT
For hardcore gamers who want the best in mobile gaming, look no further than the OcUK Hardcore Gamer P177SM. There is no more powerful or better constructed option, with the latest 4th generation (Haswell) Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Hardcore Gamer P177SM with an Intel I7 Extreme processor too. Though our own in house testing shows the best bang for buck performance comes from the Intel Core I7 4800MQ & 4700MQ processors, so we highly recommend these when choosing a processor option.
This chassis uses the absolute very latest in technology such as SATA3, USB3.0, Bluetooth, WiFi but the most impressive of all is the fact this system features an ATI Radeon HD 8970M with 4GB of GDDR5 dedicated memory for absolutely blistering performance. With so much video memory and such horsepower you can even output to a 30" monitor and still have great gaming performance or run a multi-monitor setup.
With an LED backlit 17.3" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the ATI HD 8970M's onboard graphics. The OcUK Hardcore Gamer P177SM features high quality THX speakers with Sound Blaster cinema technology for the ultimate gaming experience.
For memory we only use the highest performance and most reliable for laptops, which is Corsair Vengeance which is set to run at 1600MHz with T1 memory timings resulting in absolute instant response. 8GB is the default choice which is more than adequate for all task and gaming, we only recommend 16GB kit if your also doing a lot of photography work or heavy multi-tasking. Corsair Vengeance 1600MHz will extract the very best performance from the OcUK Hardcore Gamer P177SM causing zero bottlenecks in the system.
For hard drive options, we recommend the primary drive as an SSD drive, this means from point of pressing power on your should be at the Windows 8 Desktop in approx 10 seconds and with an SSD applications and games load more or less instantly. Of course if you preferre capacity you can choose a large capacity HDD or a Hybrid drive too. Our recommendation is to select an SSD for the primary drive along with a HDD as the secondary drive for storage.
When you buy a Overclockers UK system/laptop the only software you’ll find is your choice of operating system. We guarantee that there will be no third party apps, useless bloatware or unnecessary trial software, to keep your machine running at peak performance from the start. We also only install the latest drivers which are proven to provide maximum performance when gaming.
Specification:-
- Operating System: Choose from the drop down options!
- Display: 17.3" SuperBright LED True HD Display (1920x1080 Resolution)
- Graphics: AMD / ATI Radeon HD 8970M 4096MB GDDR5
- Storage: Choose from the drop down options!
- Optical: Choose from the drop down options!
- Illustrator touchpad (glows when used)
- Sound Blaster HD Audio
- Mic Noise Suppression
- Dolby Home Theatre®
- 4W THX Stereo Speakers (2W x 4)
- 2 megapixel Webcam
- Processor: Intel® Core™ i7 4th Generation Haswell Processor - Choose exact model from drop down options!
- Memory: 4GB DDR3 System Memory at 1600MHz (4GB x 1) OR choose 8/16GB DDR3 Options
- Main Chipset: Intel HM87
- Communication: 10 / 100 / 1000 Gigabit Ethernet LAN,Wireless LAN, Widi Support
- WiFi Options: Choose from drop down menu
- 1x HDMI Port
- 1x DisplayPort
- 1x Mini-DisplayPort
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x Mini IEEE 1394a port
- 1x eSATA Port (USB 3.0 Combo)
- 1x DC IN
- 1x RJ-45 Jack
- Kensington Lock: YES
- Full Range AC adapter, AC in 100~240V, 50~60Hz, DC output 19.5V, 11.8A, 230W
- Removable 8 cells Smart Lithium-Ion battery pack, 76.96WH
- Battery life: 300 minutes (with UMA mode, 76.96WH Battery)
- Dimensions: 414 (W)x286 (D)x 25.3~46.1 (H)mm
- 4.1Kg,including ODD and 76.96WH Battery
- 9in1 Card Reader
- 2yr Warranty (1yr Parts, 2yr Labour)
Service Package
- Full 24 Month collect and return warranty (12 month on parts)
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this Notebook for You?
Immense performance, powerful graphics and sleek hardware all combine to create the "OcUK Hardcore Gamer P177SM, perfect for the gaming enthusiast.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow between 48 and 96 hours for your system to be built and configured. This may take longer during busier periods. You can choose from the drop down options to jump the queue by selecting one of our Fast Track options. If your choosing the 24hr next day service, to get the laptop delivered next working day you need to order pre 10:30am to give us enough time to build, test and get your laptop shipped out, otherwise you will get it the following day.
Only £720.00 inc VAT.
ORDER NOW
OcUK Tech Lab - V12 Watercooling Kit 360 @ £159.89 inc VAT
Until now, watercooling has been off-putting.
The costs involved and the myriad of choices available can be confusing to newcomers who crave the high performance, silence and gorgeous aesthetics that a watercooled system provides.
In the past, Watercooling Kits have nearly always had cheap, low quality parts in the box that are prone to failure or were generally low quality.
OcUK have stepped in and solved this problem. With each OcUK Kit you get everything you need to watercool your PC along with full installation instructions. this means you cant go wrong. You don't run the risk of ordering the wrong parts, and you are assured out of the box compatibility.
Pair this with the Ultra High End performance of EK products and you have the quick and easy solution you need to gain those extra MHz
Ideal for first time watercooling enthusiasts and seasoned veterans alike.
Component List:
1X 360mm Radiator Option
Choose a radiator that suits your cooling requirements. Standard is a great choice but if you want to go even more extreme, there is Advanced and Premium for enthusiasts who want to take it to the next level!
1X XSPC D5 Dual Bay Reservoir/Pump Combo
The worlds best watercooling pump mounted to a high performance, stylish reservior. This is the ultimate choice for a tidy system with easy to fit and fill internals.
1X XSPC Raystorm [Choose your socket type from the drop down menu]
The most advanced high performance CPU waterblock on the market. LED customisation and astounding flow rates make this perfect.
1X XSPC K2 Thermal Compound
Included with the Raystorm block is a tube of K2 Thermal Paste. This high performance paste is ideal for watercooling applications and most importantly, Non Conductive.
3X Corsair SP120 Quiet Series High Pressure Low Noise 1450 RPM - 3 Pin Fan
Market leader for static pressure on watercooling radiators. Features interchangeable accent rings to customise the appearance of your system
1X Mayhems Coolant
Pick your own coolant that suits your taste and style
1X XSPC 7/16" ID [16/11mm] Clear
High quality watercooling tubing with a superb bend radius
6X XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Black Chrome)
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.
IMPORTANT:
Kit is easy to install, use and maintain (thorough installation manual is available on our forums).
This kit can also be upgraded with an additional VGA waterblock!
You will need to buy two additional fittings alongside your graphics card block.
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1150 Socket
- Intel 1155 Socket
- Intel 2011 Socket
Supported sockets with AMD Block
- AMD AM2 Socket
- AMD AM2+ Socket
- AMD AM3 Socket
- AMD FM1 Socket
- AMD FM2 Socket
***NOTE***
We endeavour to keep stock of all items at all times.
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in completing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.
Only £159.89 inc VAT.
ORDER NOW
Specification:-
- 1x HDMI Port
- 1x DisplayPort
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x DC IN
- 1x RJ-45 Jack
- 9in1 Card Reader
Service Package
ORDER NOW
Component List:
1X Mayhems Coolant
IMPORTANT:
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1150 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD AM2 Socket
- AMD AM2+ Socket
- AMD AM3 Socket
- AMD FM1 Socket
- AMD FM2 Socket
***NOTE***
ORDER NOW
