Hi there
Visit our store on 27th July and try the Asus 4k2 Monitor for yourself & Grab a great deal!!!!
As we understand the Asus 4k2 is a very expensive investment and its a very new technology, many of you would obviously like to see one in action in the flesh playing some of the latest games on a crazy PC.
So on Saturday 27th July we shall be demo'ing the Asus 4k2 Monitor on one of our flagship gaming PC's - The Ultima Hyperion which has three AMD HD 7970 GHz cards in Crossfire, so more than enough to power this incredible monitor.
Further more anyone after viewing this monitor in our shop can pre-order it IN THE SHOP ONLY for the special price of £2849.99 Inc. VAT, so that is a saving of £150 if you decide to pre-order one there and then in the shop:-
Asus PQ321QE 4K Super-High Resolution Widescreen Monitor - Black @ £2,999.99 inc VAT
The ASUS PQ321Q True 4K UHD monitor provides stunning visuals with an ultra-high definition 3840 x 2160 resolution. The anti-glare 31.5-inch LED-backlit UHD display has a 16:9 aspect ratio and 140 pixels per inch (PPI) for highly-detailed visuals.
By doubling the number of horizontal and vertical pixels, the PQ321Q True 4K UHD monitor gives you every bit of detail, far surpassing that of a Full HD monitor. With four times the resolution of Full HD (FHD) and over 8 million pixels, experience larger screen real estate and clarity you have to see to believe.
The ASUS PQ321Q True 4K UHD monitor is a 10-bit RGB panels that delivers more natural transitions between different hues and offers a more flawless image than ever before.
The ASUS PQ321Q True 4K UHD monitor is built with an anti-glare Indium Gallium Zinc Oxide (IGZO) panel rather than traditional amorphous silicon. The IGZO panel supports much smaller transistors than amorphous silicon, which allows for much smaller pixels and much better detail. Couple with an ultra-wide 176-degree viewing angles on both vertical and horizontal planes, get a pristine image from virtually any angle. What’s more, the IGZO panel supports increased pixel transparency and reduced current leakage for increased energy savings.
The ASUS PQ321Q True 4K UHD monitor features DisplayPort and dual-HDMI ports inputs to connect to your various devices and PCs simultaneously. Built-in 2W stereo speakers simplify free space from needing separate speakers for a complete audio visual experience. Picture-by-picture (PBP) mode splits the screen down the middle to display content from two separate sources side-by-side to view images from different signals and easily switch between the main and PBP source, including audio. The thinnest 4K monitor available, the ASUS PQ321Q True 4K UHD monitor measure only 35mm at its thickest point, showcasing a modern design fit for anywhere in the home or office.
Features:-
- 31.5-inch 4K display with ultra-high definition (UHD) 3840 x 2160 resolution and 140 pixels per inch (PPI) for impeccable visuals
- An anti-glare, LED-backlit IGZO display delivers crisp, precise images with energy efficiency with an ultra-wide viewing angle
- DisplayPort and dual HDMI ports, Picture-by-Picture function, and built-in dual 2-watt stereo speakers
- The thinnest 4K monitor available, the PQ321Q is wall-mountable with full tilt, swivel, and height adjustment
Specification:-
- Panel Size: 31.5" 16:9 Widescreen
- Panel Type: IGZO / LED Backlight
- True Resolution: 3840 x 2160
- Pixel Pitch: 0.182mm (140ppi)
- Brightness: 350cd/m
- Contrast ratio: 800:1
- Display Colours: 1.07 Billion (10-bit)
- Viewing Angle: 176 / 176
- Response Time: 8ms (Gray-to-Gray)
- Trace Free Technology
- HDCP Support
- Colour Temperature selection
- Gamma Adjustment
- 2W x 2 Stereo Speakers
- Connections: DisplayPort, RS-232C, PC audio line-in, Earphone out
- Power consumption: 93W
- Kensington Lock
- Dimensions with stand: 750 x 489 x 256 mm (WxHxD)
- Dimensions without stand: 750 x 441 x 35 mm (WxHxD)
- Weight: 13kg
- Warranty: 3yr
Was [£2,999.99] Inc. VAT
Only £2,849.99 inc VAT (£150 SAVING!) - ONLY VALID IN-STORE on 27th July!!
ORDER NOW
We shall also be doing some incredible shop ONLY deals that weekend available ONLY IN-STORE, so be sure to ask about the deals when in the shop.
If you intend on coming, please reply to this thread in Latest News to say you are attending.
Features:-
Specification:-
- HDCP Support
- Gamma Adjustment
- Kensington Lock
- Weight: 13kg
- Warranty: 3yr
ORDER NOW
