Project OTT
i love that case :D, i have the 410 phantom, and thats big and looks amazing, but i am tempted to move with times and get a 810 instead :D
good job btw, look good :)
Lovely case that, really nice build. Congrats! Could you explain what Litecoin mining is though? Not really heard about that before.
It is like folding or seti@home using graphics cards to process massive amounts of virtual coin transactions to earn virtual coins.
Do a Wiki on Bitcoins to learn more, very similar.
Almost finished.
Swapped some of fans around, got some 140 nx fans for the top and moved the blue led fans I have to the bottom to give some colour in the case.
My LED strip arrives on Monday and I have also added a new fan controller to the front to replace that horrid nasty one I had before.
Next up will be some shiny compression fittings, should really finish off the whole build.
All finished now.
Added some NZXT blue LED's to light up the dark case.
These are really nice, standard Molex connector and board is mounted onto a standard card plate to attach to the PCI plate holders like a graphics card. From there and outside you can select 1 - 3 intensity of the lights as well as power them off. Recommended and only £10 for 1m strip more than enough to light a NZXT Switch 810 case.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-057-NX
Some final pictures. I will change the mouse to blue LED as well :)
Side view
Front view with front cover off in this heat to aid exhuast fans.
