Give me a game that uses more 2gb of vram and gives acceptable fps on a single screen using a Titan, you have an open goal take your shot.
I don't think we will ever see it as my Titan is just not fast enough, perhaps you can think of an AMD card that is.
A 7950@1100mhz is not noticeably faster than a 770. Its about equal to a stock 7950GE which in most cases is a bit slower than a stock 770. Its also as always a silicone lottery when it comes to overclocking. I had 3 7950s that was unstable at 1100 on air. Added to the fact 770s can also be overclocked, these 2 cards shouldn't really be compared as equals.
One last question if I may? My current card uses 2 x 6 pin cables and the new cards I've seen use a 6 and 8 pin. My psu (hx520w) doesn't have any 8 pins so could I use an adapter or something on my 6 to convert to 8?
thought theu were both OC version of 7950 and i haven't heard yet of a single 7950 that does not oc at 1100 on air ...weirdMax payne 3 max out use about 2GB if not.more on a single monitor i say that becaus i used to play it on a MSI GTX580 lightning XE with 3GB vram ... Simple as that the more the vram you got the better it is.![]()
As I've said, if you understand the workings of 3D graphics, you wouldn't be saying this.
Yeah, no. A GE 7970 is noticeably faster than a 770.
So there is a different between a 7950 @1100 and a 7950GEthought theu were both OC version of 7950 and i haven't heard yet of a single 7950 that does not oc at 1100 on air ...weird
I have a gtx770 & play games like BF3, Bioshock, Metro Last light. I play on 1080p @ ultra and i rarely go below 60fps, BF3 hovers around 120fps > 50fps lowest with lots of action on a 64 player map, Bioshock is high 90s > 120fps, Ive not tested teh fps of metro but its around 60fps on the highest setting.
Ive not found 2gb limiting but i only have a 1080p monitor, if you play any of these games or similar you wont be disappointed.
Taken from the Battlefield 4 Alpha.
Couple of things to note. The game has a lot more to come in the way of optimization, so those vram usage requirements might come down. I also doubt there is much caching going on here as i find caching only occurs once a new level is loading, at least for me on 3gb at 1440p. However you have to remember that the alpha has a lot of textures missing so you could counter the optimization angle by saying those requirements will go up once the levels have full textures available rather than blank textures like in the picture below.
If that above chart is true, then it might well be brown pants time for our 2gb friends and they will have to start sacrificing image quality details.
There is a slight ommission here, no 2GB cards were tested at the same settings.
BF3 shows very similar memory usage on 3GB+ cards but lower usage on 2GB cards at exactly the same settings.
For example this is the reported memory usage I am seeing (have seen) in BF3; Full Ultra settings at 3600x1920:
GTX670SLI - 1.98GB
HD7970 - 2.5GB
GTX780 - 2.4-2.5GB
What we really need to know is how mcuh VRAM is actually required, not how much the game happens to be using at any one point.
