- 30 May 2012
- Bristol
Just opened a savings account with Barclays along with a current account for online banking. I upgraded to PINsentry so that a new code is generated by using my card and entering my PINinto the reader, each time I log on and each time I add a new payee. I'm sure many of you use these card readers for online banking. This all makes it very secure against online security attacks, but after doing a test transfer to one of my other accounts with Nationwide, I realised that the card and PIN number were the only things necessary to both gain access to Barclays online banking, and to set up new payees and complete a bank transfer to them (of course a card reader device is also needed, but they are the same across all the banks, Nationwide card readers function exactly the same as PINsentry readers).
Therefore, as said previously although it may be secure again online attacks, against physical theft of the card and PIN number it is very weak. For example, if someone managed to catch a glance at your PIN number in a shop, they could steal your card later on and rinse your account of the entire balance in seconds on their phone. Less time than it would take for you to cancel the card no doubt. Now you should hopefully be able to reclaim that money, but it shows that if anyone happens to see your Barclay PIN number, the balance of any Barclays accounts you hold are now as easy to acquire as cash stuffed in your pockets.
This is a warning to Barclays current account users. I have emailed them to suggest using a passcode in addition to PINsentry, not as an alternative option at log in, similar to my Nationwide account which uses the same card and reader system but also requires a 10 digit membership number. I'd also urge people to also email Barclays if you take financial security seriously as hopefully they might actually change something.
