** LOADS OF NEW XSPC **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Loads of new XSPC up for pre order right now.
This is mostly bits and bobs but does include the long awaited reservoirs.
Very excited to see these, awesome looking products.
Stock should be here next week :)
XSPC 140mm Radiator Gasket @ £2.99 inc VAT
XSPC radiator gaskets are designed to reduce the air loss between the radiator and the fans. This can improve airflow and cooling performance, while also reducing vibrations between the fans and radiator.
Specification:-
- 3mm Thick Neoprene
- Self Adhesive Backing
- Dark Grey Colour
**Compatible with: EX140 and most other 140mm radiators.
Only £2.99 inc VAT.
ORDER NOW
XSPC 280mm Radiator Gasket @ £2.99 inc VAT
Specification:-
- Dark Grey Colour
**Compatible with: EX280 and most other 280mm radiators.
Only £2.99 inc VAT.
ORDER NOW
XSPC 420mm Radiator Gasket @ £3.95 inc VAT
Specifcation:-
- Dark Grey Colour
**Compatible with: EX420 and most other 420mm radiators.
Only £3.95 inc VAT.
ORDER NOW
XSPC 560mm Radiator Gasket @ £3.95 inc VAT
Specification:-
- Dark Grey Colour
**Compatible with: EX560 and most other 560mm radiators.
Only £3.95 inc VAT.
ORDER NOW
XSPC 140mm Universal Radstand @ £9.95 inc VAT
XSPC 140mm Universal radstand suitable for single, dual, triple and quad 140mm radiators.
Features:-
- Steel
- Powder coated Black Finish
Support List for XSPC Radiators
- EX120
- EX240
- EX360
- EX480
- RX120
- RX240
- RX360
- RX480
- RS120
- RS240
- RS360
+ Most other 140mm radiators
Only £9.95 inc VAT.
ORDER NOW
XSPC Razor SLI Flow Bridge (3 Slot) @ £8.99 inc VAT
Easily connect two blocks in SLI. Three slot spacing
Specification
- Dimensions: 25(W) x 25(L) x 42(D) mm
**Compatible with:
Razor GTX680
Razor GTX690
Razor GTX670
Razor HD 7970
Razor GTX Titan
Razor HD 7990
Only £8.99 inc VAT.
ORDER NOW
XSPC Razor SLI Flow Bridge (4 Slot) @ £10.99 inc VAT
Easily connect two blocks in SLI. Four slot spacing
Specification
- Dimensions: 25(W) x 25(L) x 62.5(D) mm
**Compatible with:
Razor GTX680
Razor GTX690
Razor GTX670
Razor HD 7970
Razor GTX Titan
Razor HD 7990
Only £10.99 inc VAT.
ORDER NOW
XSPC Razor SLI Flow Bridge (6 Slot) @ £12.95 inc VAT
Easily connect two blocks in SLI. Six slot spacing.
Specification:-
- Dimensions: 25(W) x 25(L) x 103(D) mm
**Compatible with:
Razor GTX680
Razor GTX690
Razor GTX670
Razor HD 7970
Razor GTX Titan
Razor HD 7990
Only £12.95 inc VAT.
ORDER NOW
XSPC Photon 270 Tube Reservoir @ £46.99 inc VAT
The XSPC Photon is the ultimate tube reservoir for PC water cooling. The tube is made from a quality toughened glass, which is both crystal clear and highly resistant to staining. In the center of the tube is an acrylic lighting pole that connects to a 5mm LED on the base of the reservoir. The LED is easily replaceable so you can match the lighting colour to your build.
Unlike other tube reservoirs, which use cheap plastic brackets, the XSPC Photon has high quality CNC cut aluminium bracket. The bracket connects to both ends of the reservoir which give a solid hold without blocking the view of the tube.
Each reservoir is hand assembled and pressure tested before sale to ensure reliability.
Specification:-
- Tube Material: Glass
- Cap Material: Acetal
-Bracket Material: Aluminium
- Dimensions: 270 x 75 x 75mm
- Capacity: 690ml
- 3x G1/4" Ports
- 1x 5mm LED Hole
- Individually Pressure Tested
**Supplied with 5mm white LED, G1/4" plug and screw set
Only £46.99 inc VAT.
ORDER NOW
XSPC Photon 170 Tube Reservoir @ £37.99 inc VAT
Specification:-
- Bracket Material: Aluminium
- Dimensions: 170 x 75 x 75mm
- Capacity: 410ml
- 3x G1/4" Ports
- 1x 5mm LED Hole
Only £37.99 inc VAT.
ORDER NOW
XSPC G1/4" to 3/8" ID, 1/2" OD Compression Fitting (Chrome) @ £2.99 inc VAT
SPC have designed an excellent Low Profile compression fitting.
Despite the low profile the tail length of the fitting is the still the same length as other brands so there are no issues with how well these fittings will hold the tubing securely in place.
XSPC has also introduced the 'coin installation' design. It's always been tricky to tighten compression fittings in to blocks as they just don't have a hexagonal base, so you've never been able to use tools to tighten them up and with using pliers you run the risk or damaging or marking your fitting.
XSPC have made a handy slot in the tail part of the compression fitting that means you can tighten the fitting in place, with something as simple as a coin.
Finally the finish of these fittings is exeptional, far better than many of their rivals.
Specificaiton:-
- Chrome Finish
- For 3/8" ID, 1/2" OD Tubing (10mm ID, 13mm OD)
- Low profile design
- G1/4" Thread
- Easy tool free coin installation
Only £2.99 inc VAT.
ORDER NOW
XSPC G1/4" to 3/8" ID, 1/2" OD Compression Fitting (Black Chrome) @ £2.99 inc VAT
Specificaiton:-
- Black Chrome Finish
- G1/4" Thread
Only £2.99 inc VAT.
ORDER NOW
I'm looking forward to the day i'm allowed to buy some custom watercooling :D
I like this xspc stuff looks good quality, seen lots of nice builds with it too.
should be here in around a weeks time bud. in honesty, i would get it delivered. unless you want me to give you a shout on facebook when i have a proper ETA?
Yeh if ya don't mind dude, I definitely want to one, the 270, so when ya have a better idea give me a text or Facebook or what ever an I will see if I'm in Stoke or Notts =D
Gonna try get it done before i49, or at i49 one or another ;)
dont worry about that either! she can have the box!!!
paint it pink, write Armani on it, sprinkle it with glitter and your the best fella in the world (after me of course) i mean.... all that space for ear rings and make up and such, she will definitely 100% be satisfied *.
*satisfaction not guaranteed
