Ok cheers. Thought it was about time I worked mine out
edit - are you sure that's right for 73kg of LBM?
185g doesn't sounds enough for what is 73000g of body mass.. ???
It's fine, trust me
What've you been doing generally up to now?
Your calories are pretty low, at your size you can continue to lose weight at a good rate for quite some time. Just as you have been for the past however long. If you are sticking to that diet strictly, I reckon you know already that everything's working just fine.Can anyone give me a quick review on what I'm eating at the moment?
I've lost over 100lbs of weight already but am coming towards the tail end of my weight loss but have had to kick it up a notch in terms of diet and exercise to get any results.
Current weight is around 215lbs, height of 6ft 4. No idea on an accurate body fat percentage but would guess based on photo charts at around 20%, but it's very hard to tell because of how loose / stretchy I am due to the weight loss already.
I've started a bootcamp style fitness programme and have started eating a lot more cleanly, but I'm not sure on the total number of calories I should be eating.
Below is a snapshot of what I ate yesterday, although an apple is missing from the list!
The carb, protein, fat ratio of the above is 25 / 41 / 34.
Is this an acceptable diet to enable me to lose the last stone or so I need to lose?
Edit: The Cyclone protein shake isn't a breakfast shake as such, it's one post workout and one mid afternoon.
I've only just implemented the above in the last week or so, it's far cleaner than my previous diet but more nutrient rich I think. If I'm coping on the low calories, e.g. not feeling lethargic, is there any need to up them? I can up the calories fairly easily if needed but I feel energetic enough so not sure whether to or not.
I think you misunderstood his chart. His carbs are around 100g. His protein at 160g or so is adequate.Calories seem way too low to me, also try and get a better breakfast in with a high fat and protein content.
Perhaps try knocking your carb goal down to 150 and upping your protein.
The way I see it, you want to be able to lose a nice amount of weight whilst eating as much good stuff as you can, so up your calories a bit and see how the weight goes.
 Or maybe I miscalculated the Fat percentage? 21  seems quite a lotNot to mention the dehydration associated with alcohol and all the other balances in the body it's going to distort.
In generally if you wanted to have a low fat day and drinks in the evening then this sounds like the most logical approach but regularly going on a bender is going to make life quick difficult as you'll feel crap, have to fight hunger and perform poorly.
21% BF isn't as high as it sounds, but a huge difference exists by dropping just a few percent.Great post thanks a lot.
Base Metabolic Rate (BMR) = 370 + (21.6 x LBM)
Where Lean Bodymass = [total weight (kg) x (100 - bodyfat %)]/100
LBMs = [77.5 x (100 - 21)]/100 = 61.225
Base Metabolic Rate (BMR) = 370 + (21.6 x 61.225) = 1692.46
My BMR works out as 1692 - seems rather weird. I'm quite skinny but have a bit of belly. So ideally I need to lose extra baggage first them start building mass? At the moment I'm do a fair bit of weight training but the belly doesnt seem to want to goOr maybe I miscalculated the Fat percentage? 21 seems quite a lot
Maximuscle Cyclone
Maximuscle Cyclone
Maximuscle Cyclone
Maximuscle Cyclone
