Another pointer for full frame is viewfinder. It's so much nicer having a big bright viewfinder.
Yeah, it helps you spot people hanging about on the left of your photos
Yeah, it helps you spot people hanging about on the left of your photos![]()
DOF is relative, sometimes it's a few millimetres, other times it's a few meters.
An easier way to think of it, is that FF will give you between a 50-60% shallower DOF or 50-60% more bokeh goodness. 50-60 being the different crop factors of different manufacturers.
The TC I linked to will lose around 5% sharpness. Less than the sharpness lost through using a crop sensor over a full frame sensor.
For the casual reader about to jump on that statement: I'm not saying the sensor itself is sharper, but that it utilises more area of the lenses image circle and in doing so squeezes out the maximum resolution of a lens
F8 focuses fine on my FF's. FF is like F5.6 on a crop anyway, so 560mm F5.6 doesn't sound so bad to me.
Of course if this telephoto stuff was really a concern, you would just get a FF with high pixel density, or just get a dedicated APSC to use for birding and the like, and the FF for everything else.
Crop cameras have a lack of shallow depth of field? I've not noticed....
Full frame has a narrower depth of field for the same lens and framing compared to crop, but I've never found the matter a few millimetres difference in field depth to be anywhere near attractive enough to make the switch.
Noise, definitely. Just not enough of a draw for me considering the disadvantages.
The 6D makes my future choices even more confusing..For £1900 I can get a 6D with EF 24-70mm f/4 L IS from HK, and I'm about to invest almost half of that in EFS lenses now...
I need to think this through..
I've got straight up gear envy. I'm not even going to lie about it.
Plus a lot of the stuff I'd like from, say, a D800 has little to do with the size of the sensor. Focus points, ISO capabilities, even number of nobs and buttons and grip sizes are all just.. better on the FF cameras. It's a bonus they are FF in my eyes, rather than FF necessarily being a reason to upgrade.
Sure, but really if we're talking the about the "limitation" of a crop sensor, then aren't we talking about the DOF at max aperture? I would have thought equally framing a scene at f5.6 on FF and F4 on a crop is going to give pretty much identical results assuming half decent glass- you just choose the aperture for the required field depth.
For creative purposes the biggest difference case is going to be relatively foreground subject and blurred background. And even in this case, the DOF advantage is going to be fairly slim- i.e. 150% of "razor thin" is still "razor thin"?
Note, I'm not trying to fan the FF vs crop flames, just discussing! To be honest I "want" a full frame body just because. Except when I look at it analytically (boring)... at my budget there's nothing that gives me the features of my cheap crop bodies, particularly frame rate. I think I'd get more benefit from a £500 lens than a 5Dmk1 at the moment, but that's just me. If you have the disposable to buy a new FF body, there's really no reason not to- the 5D3 does everything the best crop bodies do, and more.
They you are making a classic mistake of thinking shallow DoF == good Bokeh.
Bokeh doesn't have anything to do with the actual depth of focus. Bokeh describes the quality of the out of focus rendering. You can get great Bokeh with 10s of meters of DoF and terrible Bokeh with 1mm DoF. I get great Bokeh shot at f5.6 on my 300mm + 1.4. I get poor Bokeh on my old 50mm f1.8D. But even on that lens I can do things to improve the quality.
Bokeh is dependent on lens design, background, subject distance, backgound separation. It doesn't spend on DoF. Of course if you have used hyper focal focusing and everything is focused then you have no Bokeh, but as soon as you have our of focus layers and in focus layers then you have Bokeh, regardless of the DoF.
I don't know where you get that 5% from. I use the exact same TC a lot,the difference it makes to image quality on my 70-200mm f2.8 and 300mm f4.0 are highly visible, and that is at a much lower pixel density than the D800 for example.
And yeah, you mind find an equivalence of f/8 using a TC nor the same lens as f5.6 on crop but what have you really gained. Or much.
My particular situation, I have. 1.5x crop body and use a 300mm f4 with and without a 1.4xTC. How can I move to a FF body while making full use of the sensor, maintaining the same reach or preferably increasing reach while not increase the cost or weight of my lens selection significantly.
Pah, not all FF cameras have huge numbers of focus points
Also, D.P. you know there's a multi quote button right?
kd
Pah, not all FF cameras have huge numbers of focus points![]()
)Imo it's more about the placement or position of them that matters most. Well placed AF points allow for good composition without having to crop in post.
Too many points can be a hinderance imo as it take too long to scroll through them.
I have 51 points but only use 11 99.99999999% of the time.
I hope it's not just me, but even with these current cameras and their many focus points, it always seems to feel like they're all bunched up in the middle where I don't want them, and takes an age to scroll across them all. I suppose the value is in finer-grained focus tracking (assuming you want to track something in the middle of the frame)
How many full length (adult sized) portraits have you taken with razor thin DOF's?
If the DOF is shallow enough, it can disguise what would otherwise be ugly bokeh. However that's not what I was talking about anyway. My statement "bokeh goodness" was referring to how shallower DOF's or more precisely larger airy discs can make pictures look 'sexy', it can add a certain wow factor that F16 can't do, at least for most people as it is of course subjective.
Sometimes when in the field, clients (with a basic understanding of photography) will even declare my 85 1.4 "one sexy lens" when they see my camera's LCD.
http://photographylife.com/image-degradation-with-nikon-teleconverters
Although on further research it looks like it doesn't play well with the 80-400 like it does on the 70-200vrii.
Outside of the tele arena, you gain.. how much differs from person to person.
