Which 780 or something else?
24 Aug 2003
Gillingham Kent
Ok which one would you recommend
MSI GeForce GTX 780 Twin Frozr
PALIT Super JetStream GeForce GTX 780 OC
GIGABYTE GeForce GTX 780
The Giga has standard clocks. MSI has a boost of 1006. The Palit has a boost of 1033
I was selling my 770 lightnings SLI for a 780,but I'm having a re-think on this. I've changed my mind now and might keep them. While 1 780 would be good,but thought my 770 SLI set up is much better then 1 780. As of now the price of a 780 is still too high for the performance it gives.
If you want a 780 I say any of them will be fine.
Cheers retro. Yes they are not cheap could go 770 sli or even 7970ghz cf. Just fancy one card only (might add another later on). Have 570trisli at present just fancy a change along with a 4770k and giga z87oc. Just unsure which way to go
For warranty EVGA,Gigabyte or MSI are the best choice. Either of them would be good if you ever need to RMA in the UK..
I'd wait a few weeks and see what prices the Lightning and Classified come in at, both should come in at stock Titan beating performance & both will have unlocked voltage if thats the kind of thing you're after.
Still not worth it tbh,but it's up to op to decide?
I would think they will have a price tag of 600 notes or there abouts. The ones I listed were less than 520
Out of the three mentioned, the Gigabyte and MSI cards would be the best of the bunch. Their warranties are the best and both cards offer a decent cooling solution. I'd go for the cheapest of the two really, unless you fancy waiting and dropping more money on the Classified/Lightning versions.
