Does that not get roasty toasty at 1.28V? I get temps of up to 78C at 1150/1450 @ 1.19V!
I tried upping my overclock to 1150/1400 and it crashed and exited out of the test due to a driver failure etc.
Do I need to adjust the voltage? I have already moved the slider to +20%
mine is 1150/1575 stock volts![]()
My slider wont go past 1200 in afterburner![]()
Hi, new to over clocking so this might sound daft but if you are running crossfire and you use afterburner to over clock when you change the clock settings does the over clock apply to both cards or do you have to do both cards seperately?
