Fixture list generator
17 Jan 2006
Dundee
I'm in need of a fixture list generator. Now whilst there are an abundance of these on the web none come with the ability to apply rules.
For example the league I am in consists of 12 teams and each play each other home and away.
Sounds simple and in theory it is but the problem I have is that 8 of the 12 teams are and A and a B team from the same venue and neither can be at home or away on the same night.
Teams are
Docs A
Docs B
Dundee A
Fairmuir A
Fairmuir B
Michelin A
Michelin B
North End
North End W
Olde MIll
Olde Mill B
Olde Mill C (Can be ignored as a team sharing a venue)
So when any A team is at home the B team must be away and vice vesra.
I have done a full set of fixtures using one of the on-line generators and proceed to move the fixtures around to accommodate, but that then really messes up the running order meaning some teams will play at home 3 weeks straight then away for two and so on.
To sum things up the rules are :
1. A & B Teams must not be at the home or away on the same night.
2. Each team must play their fixtures in a Home/Away/Home/Away order
3. Each team will play 5 or 6 matches at home in the first 11 and then 6 or 5 away in the second round of matches.
Any ideas as to where I can find a buit of software to accommodate this.
Cheers.
Try this.
https://dl.dropboxusercontent.com/u/8015999/fixem swaordfish.xls
https://dl.dropboxusercontent.com/u/8015999/readme.rtf
The readme refers to a previous version and has stuff for some other files, but I'm too lazy to edit :p.
If you need more help email me via trust.
Kinda got it working but the spreadsheet allows for teams to not play on the same day part let's it down. The teams have to play on the same just not both at home.
Is this your code? Impressive.
Thanks. It originally started as an MS-BASIC program many years ago! It seems to be permanently 'a work in progress'
There seems to be bug regarding teams playing on the same day and maximum number of matches. I'll try and fix it (again).
edit
fixed (I hope)
https://dl.dropboxusercontent.com/u/8015999/fixem swordfish.xls
