A Ford Mondeo is better in every single way.
lies
lies
Beware of the Nav - it does not support postcode lookup.
This is not correct, at least on the last 2 I have had.
Sorry but an Insignia is WAAAAAAAAAAY better than a Vectra - and I'm a Ford fanboy!
Sister in law's hubby has an Insignia for commuting twice a week between Blackpool and Bristol and it's fine.
I wouldn't be seen dead in either to be honest.
Peasant mobiles!
They are both bland commuter boxes, it's just a question of configuration and which one you prefer the look of!
In all honesty, I'm not a massive fan of Fords but I can appreciate them for what they are.Do you actually know this or are you just a Ford fanboy?
Cheap is a relative term. Worth a lot more than in the UK anyway.You drive a cheap Z3 dont you?
Slightly off topic but has anyone here driven the VXR?. Seem to recall James May said it was pretty good when TG tested it?. Just curious.
But yes, it's 12 years old now.
Don't you drive a cheap Lexus and a cheap Porsche?![]()
And it isn't cheap to run
Just picked up my new Insignia (my 3rd one).
Switched from a 2.0 Diesel, to a 1.5 Petrol Turbo...I hear you have to run the petrol cars in before they start giving fuel efficiency is that correct?
At the moment my economy is really bad
Thanks Prophet, I mainly use the car around town picking/dropping kids to school etc...would have thought a smaller engine would be more economical. Does the type of fuel make a difference? Current using shell more expensive than Asda what I used to use before
