High quality light weight cases
19 Oct 2008
Any recommendation on light weight cases? I have an Akasa Eclipse case at the moment (since 2009) which I bought partly because at the time it was pretty lightweight (8.5kg if I remember correctly). Are there any newer and better high quality cases that compare?
Ah, I wasn't considering non full ATX options, but it is possible. Looking at it I think itx is possible.
Just needs to be light and mobile. Not interested in LAN's, just move about quite a bit. Needs to be able to house good graphics card and just one SSD really, that's all I need in another machine.
Lian Li A10 midi case for £80 from a certain competitor...
You will not find a case with a higher class finish then this case for the any where near the same money.
