Best tablet for 40-60 quid?
Not sure how good they are as £60 is pretty cheap but what about the Acer Iconia tablet? It's around £70 but you may be able to snatch one up for £60 on some site.
Just don't get any unknown brands. I've made that mistake before!
Which one is that also what is galaxy tab 2 like as they seem to be going around the similar price used on the bay. Tbh tho id like to get somit brand new for 60-70 at a push tho. It is for a birthday after all.
£70 you'll struggle. BRAND new in shops are around £130-£150 for the nexus 7 and Galaxy tab 7.You're probably going to have to buy second hand.
If you can get the galaxy tab then that's a better option than the Acer. The Galaxy tab is my favourite tablet.
Take a look at Ainol's range of tablets. You will be able to find one in that price range suitable for your daughters needs.
What about a blackberry playbook? pretty sure they come in under £70 now. Not sure how many of the android games are compatible since they've made it android compatible though.
