680 and 770
los
los
26 Jun 2011
Great Yarmouth
Am I right in thinking that if they are both clocked at the same speed they would have exactly the same performance? Can you sli a 680 with a 770? Thanks
No............which ever card runs the lowest will bring the other card down to its speed.
An i don't think you can run 2 different models like 6x with a 5x or 7x series im sure they must be the same series of cards although the brand doesn't matter
It has to be the same chip series and vram amount. a 2gb and 4gb wont work
Yes they would have the same performance at the same vram and core clocks, they are the same thing.
No, you can't SLI them
Also, SLIing 6xx/7xx cards at different clock speeds doesn't change the speed of either, they are independent
Theres a thread knocking around here some where from the last 2-3 days clearly explaining that the cards will not run at the same speeds an that they will be bottlenecked by the lower card.
Il have a look around for it an post or pm you the link.
The performance will be dictated by the slower card but the clock speeds will be independent
